Old 06-29-2012, 09:51 AM   #31
Well, if anyone is interested, I'll give it a shot- snap some pics and report back... I have 30 and 50 amp cables (different rigs)
strokendiesel002 is offline   Reply With Quote
Old 06-29-2012, 02:05 PM   #32
jimh's Avatar
i would like to see the pictures. would also like to know if u had any problems winding that 50A cord.
jimh is offline   Reply With Quote
Old 08-03-2012, 11:10 PM   #33
Smile
Here is the Harbor Freight hose reel (item #46342). It was $20, and took about 10 min. to put together. It doesn't include the allen wrench necessaryto complete assembly, but otherwise it went together nicely.
Starting the cable- I used a little pin to hold the end of the cable while winding
another shot of the clip
25' of 30 amp cable. It didn't seem to stress anything.
I'll try to remember to grab the 50 amp cable next time I go to the camper, and I'll take pics and do a little stress testing. If it works, I'll mount it andtake more pics!
Jimmy
Current TV's -'05 Silverado 3500 DRW Duramax; '07 G.C. Hemi; '96 F250 Powerstroke
Previous TV's '94 G.C. L6 and '05 Dakota QC 4.7
Family Camper's -'96 Coleman SunValley;'00 Forest River Shamrock 25'; '12 Keystone Raptor 41'
Old 08-03-2012, 11:22 PM   #34
ironj's Avatar
Hmm....i like that....and harbor freight too.....wrap that 50 and let us know!...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 08-04-2012, 07:47 AM   #35
jimh's Avatar
i'm interested in what and how u mount them. what abt doing the same with the water hose?
Old 08-04-2012, 09:58 AM   #36
I think this would work fine for a water hose as long as it is a 25' hose.
I've got several ideas for mounting it. One involves a piano hinge and some plywood, mounted vertically as it is designed to be, if the space is there... maybe even for the electric and water hose (electric on the inside). I'll sketch it ok and post some pics later, but im thinking while in storage position it will be latched against with the front or back wall of the front storage capacity. If the takes up too much room, I may weld a ring around the outer perimeter and mount it horizontally to the roof of the storage
Jimmy
Old 08-04-2012, 10:21 AM   #37
ironj's Avatar
Awesome.....get it all figured out so we can steal....errrrrrr......BORROW your hard work........you will of course get all the credit and i will buy you many virtual beers
Old 08-04-2012, 10:24 AM   #38
jimh's Avatar
what abt along the same line as mounting it to a board, have it store horiz attached to the overhead and swing down into a vertical position to wind and unwind?
seems like the one i saw pictured (that i can't find) mounted them side by side but i can see where that can block part of ur access.
Old 08-04-2012, 10:50 AM   #39
That could work depending upon the amount of space available
ID:	17509   Click image for larger version
ID:	17510   Click image for larger version
Jimmy
Old 08-04-2012, 10:54 AM   #40
Sorry about the pics, first time uploading from a phone
Jimmy
50 amp, led pad
