Old 05-26-2015, 04:19 PM   #1
Somewhat right of center
Crabbyguy's Avatar
50 to 30amp
Just a FYI. My Crusader came with a 50amp power cord only because the factory wired it to add another AC unit. Anyway, I'm getting a little tired of hauling out the 50amp cord so I decided to buy a 30amp 25' cord for easier hook up and leave the 50' 50amp beast in the storage compartment. Just an idea for you if you're in the same situation as me.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 05-26-2015, 04:50 PM   #2
My friend had a Huge 50A Pusher he used the (30A) power cord 99% of the Time! Even with a Power cod winder those (50A) are a BEAR below 40Deg. Youroo!!
Old 05-26-2015, 05:09 PM   #3
This is a great idea. I think I will do the same, I hate that huge heavy cord.
larochelle is offline   Reply With Quote
Old 05-27-2015, 07:15 AM   #4
Crabbyguy's Avatar
Don't forget, you'll need one of these:
Amazon.com : Milspec Direct 10-Gauge STW RV/Motorhome Adapter, 30 Amp Male RV Plug to 50 AMP Female Twistlock Connector, Yellow : Patio, Lawn & Garden
Old 05-27-2015, 09:35 PM   #5
Anacortesians
Disconnect the 50A, otherwise the pins will be hot from being in parallel with the 30A cord.
Frank and Eileen
No longer RVers or FR owners
Old 05-28-2015, 07:10 AM   #6
Crabbyguy's Avatar
Not sure I follow you but I won't be plugging into the 50A service, only the 30A.
Old 05-28-2015, 07:18 AM   #7
Poppy94's Avatar
Ditto, I don't follow either, I just use the 50a @ the house & the 30a adapter & not run the ACs. At campsites, I plug in & use 50a, am I doing this wrong on my crusader?
Poppy94 is offline   Reply With Quote
Old 05-28-2015, 02:49 PM   #8
Crabbyguy's Avatar
No you're not doing anything wrong. The only way I see anything heating up is somehow plugging a 30A cord into a 50A service which can't be done since the plugs are different. I'll be using a 50A female to a 50A male adapter from the camper to a 50A female/30A male dogbone adapter to the 25' 30A cord, then plugging into the 30A pedestal at the campground. All thoughts and input is welcome. My son is an electrician, I should just call him.
Old 05-28-2015, 03:15 PM   #9
Poppy94's Avatar
I've got to run a 30a power pedestal here at home, but in the meantime, I have a heavy duty extension cord 110 to a 30a-110 adapter to the 50a cord. I only use it to charge the battery & chill the icebox for prep before trips. So far, no issues. Thanks for helping me out
Old 05-28-2015, 03:24 PM   #10
One of these would eliminate one of the those adapters.
http://www.amazon.com/Conntek-14381-...BDNNJNWY31ERSZ
Iwritecode is online now   Reply With Quote
