Old 03-13-2012, 03:22 PM   #11
Dave_Monica's Avatar
southernsky...if you haven't already, a trip to the scales would be worthwhile to determine what the loaded pin weight actually is and as a % of total weight. Your problem may be reduced by adjusting the pin weight.
The pin weight on our Rockwood is 1300 lb and 15% of total weight (we have a rear kitchen floorplan). This seemed to be great when towing with my Ram 1500 as I had no incidence of 'chucking'. I'm hoping that a pin weight of about 1600 lb will be a better match with the heavier suspension of my F250. The water tank on our camper is located over the axles and doesn't impact on pin weight.
Dave
Old 03-16-2012, 09:01 PM   #12
RattVader's Avatar
Originally Posted by M109Rrider View Post
I've had similar results as Dave. I used to only carry a small amount if water in my fw tank. Lately I've been filling the tank. The ride has drastically improved and haven't noticed any real change to fuel economy.
M109Rrider,is your Ram a long bed or short bed? I can't quite make it out in your photo.
Steve & Sue
2011 Crusader 320RLT
2008 Dodge Ram 3500 (CTD) DRW 4x4
RattVader is offline   Reply With Quote
Old 03-16-2012, 09:03 PM   #13
RattVader's Avatar
Never mind.I see that it's a short bed.
Steve & Sue
Old 03-16-2012, 09:36 PM   #14
PHS79's Avatar
My dad installed the 5th AirBorne on his 34' Jayco. The camper has a pin weight of 2600ish, he said it was just over 3000 lbs when they went south for the winter a couple years ago. He has always had diesel F350 4X4 ext cab, long box, duallys for TV. He said that the 5th Airborne helped out ALOT with his set-up.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
