Old 01-15-2013, 07:49 PM   #31
Herk7769's Avatar
Originally Posted by rabraz View Post
Hey Crusader. What was it about the superglide you did not like? I just installed a 4100 Superglide but have not picked up my trailer yet so I have never pulled with it. In fact this will be my first fiver and I am a bit nervous about it all. I am curious what I need to be looking out for. Everyone I know tells me I'll never go back to a bumper pull once I hook on to my new trailer.
No worries. You will love your hitch and camper.
HAM CALLSIGN - KC3FFW
Old 01-15-2013, 08:09 PM   #32
Originally Posted by WEMig View Post
I have an older 15K with no pivot. Works fine with my Crusader. No need for a slider and I have a swb F250.
Hey WEMig.
How does your 6.2 handle your trailer? You fairly comfortable towing the load? Have you pulled across a scale while loaded just to see where the weight was sitting?? One last one, you say you do not feel you need a slider, have you measured the trailer distance from the cab after putting it into what you considered the tightest turn or backing you make? I ask because I have a headache rack and low profile tool box and I am trying to determine if I can keep those items or if I need to get rid of them to insure I do not damage my new rig.
Thanks for the info.
Name:	truck and camper.jpg
Ricky, DW Terry, 11 Kids and Grandkids who all want to go camping with me! Life is good!!
2012 F-350 SuperDuty 6.7 SRW CC, Reese Elite 30144, 2013 Puma 351THSS, 2009 EZGO TXR, 2005 Palm Beach 211 Bay, 2004 HD FatBoy.
rabraz is offline   Reply With Quote
Old 01-15-2013, 08:37 PM   #33
William
WEMig's Avatar
Hey WEMig.
The 6.2 handles it very well. I had a 2002 7.3L diesel and the 6.2 is very comparable power wise. I live in Louisiana, so I don't tackle extreme hills often. I'm very satisfied with it coming from a diesel.
I've weighed at a scale and my Crusader comes in at 11,400 with a pin weight of 2300. Truck loaded for camping has available 2240 lbs; putting me about 60 lbs over my cargo capacity. That gives me 20% pin weight. I do need to install either air bags or tembrens since my 4x4 has a bit of sag with that weight. In your set up, I would invest in a slider or remove the headache rack. You may have issues turning on uneven surfaces where the trailer nose would tend to tilt towards the cab. I'm pretty comfortable with the clearance I have turning and backing.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 01-16-2013, 10:42 AM   #34
Crusader's Avatar
Rabraz, welcome to the 5ver club. This is also my first fifth wheel. You will love pulling the fifth wheel. The first think I noticed was, no dancing RV trailer, when a semi-truck passes you. I must say, It is a new game, when it comes to backing it into a camp site. It defiantly pivots different.
What I most hate about my superglide hitch, is the jerking action as you go into and out of turns. It gives you a feel ,like as if, the trailer is coming off the truck. The truck cab jerks, and you see the trailer sliding back. I always have a loose feel in the RV king pin and the throat of the hitch. That loose feel is noticeable at starts and stops. I have adjusted that king pin “free play” several times, but its still there. I have been told by other 5vers, that “fee play” is common with fifth wheel hitches. The hitch its self is just so massive. Don’t get me wrong, the hitch has served me well. Its just not my kind of hitch.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 01-16-2013, 11:54 AM   #35
Fulltime family RVer
Originally Posted by herk7769 View Post
Emptier than this?
Slightly yes and slightly no. :-) I only have one 4" hole that's filled with the upside down gooseneck ball. But, I also have the 2 gooseneck safety chain u-bolts that are flush with the high ribs of the bed.
You uninstalls took process sounds like more work, but given the rarity of removing the hitch, I doubt that it matters. (Plus, the written word always sounds like more work- I bet I'd claim the same if I wrote my steps!)
I didn't realize that there were hitch installs with rails that came out that easily. Is that standard for the hitch? Or was the truck ordered with a 5th wheel prep? (aka, would the same setup and removal work on a Dodge?)
Thanks for the info. Neat to see the options.
Old 01-16-2013, 01:27 PM   #36
Herk7769's Avatar
The new hitch with the nylon/kevlar slide collar is very quiet. They are working on an "upgrade" to older hitches but have run into issues with "fit" and some adjustment is needed with most older hitches.
Here is what the new one looks like.
Old 01-16-2013, 02:01 PM   #37
Crusader's Avatar
Herk..............This is my hitch......she's a bigEEEE............
Old 01-17-2013, 07:43 PM   #38
Suspension
I pretty much have the same truck and had a bit of a sag when hitched to my 282txr loaded for a long weekend. About 6klbs. I installed a set of super springs and am really impressed with the difference. Great price for a suspension upgrade. I dont hardly notice the load back there now.
Thanks for your input on the truck. Its good to have first hand info.
5th wheel
