Old 11-24-2014, 06:29 PM   #1
07 ThunderRoad's Avatar
7 pin trailer cable and plug
Does anyone out there have a good high quality cable connector for the trailer to tow vehicle. I'm tired of the rotten copper connections on the trailers plug. Is there a stainless steel spring loaded plug connector?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 11-24-2014, 07:12 PM   #2
Try etrailer.com and see what they've got.
2011 Traverse LT, 3.6L, FWD
Old 11-24-2014, 07:18 PM   #3
Solid copper is your best choice for electrical connections. Get some quality electrical contact cleaner and use it religiously. You wont have any more problems.
donniedu is offline   Reply With Quote
Old 11-24-2014, 07:33 PM   #4
Campfire Master
My plug is in bed of the truck and I've not yet had any problems. If your so inclined, I ran across this a while back. I've been tempted, but not yet pulled the trigger. EZ Connector
AVid is offline   Reply With Quote
Old 11-24-2014, 07:35 PM   #5
Use this:
Dielectric Grease for Electrical Connectors, 2 oz. LubriMatic Accessories and Parts 11755
Old 11-24-2014, 08:58 PM   #6
another_newfie's Avatar
Rockfordroo has the right idea. Keep the contacts clean and keep the crud out of them and they will be fine. I have winter camped for years and the brine they spread here in Ontario does a number on the connections. Each spring I clean them and coat them and I've been trouble free.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 11-25-2014, 04:04 PM   #7
The problem I'm having is the copper connections in the plug itself from the trailer are spreading open and I'm losing the connection.
trailer
