Old 04-13-2011, 09:21 PM   #11
tbritt's Avatar
Originally Posted by grhodes50 View Post
I just went out to check and yes, there are two screws on the bottom freezer door hinge.
We did it........thanks Gary... Now to just them to fix it on site would be nice
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 04-14-2011, 08:26 AM   #12
You need to monitor your voltage on your 30amp plug when you start the AC unit. If the voltage is dropping too low then you will trip your breaker on overcurrent. The reason for this is that the motor on your compressor will compensate for the low voltage by drawing more current. This can be caused by too small of cord connecting you RV to the pedestal or the quality of shore power being poor. A 30 amp service needs a minimum of a #10 cord and this is not enough if it is over 25 feet long or so. The larger cord you have, the better. I do not have my 298bhd yet but i plan on having a couple of cords for it, one if which will be a #6 by 50ft.
2004 GMC Sierra 2500
2012 Primetime Crusader 298BHD
sbelliott is offline   Reply With Quote
Old 04-14-2011, 07:23 PM   #13
tbritt's Avatar
Up Date
Originally Posted by tbritt View Post
Been it the new 303RK for 9 days now and have a few things or issuses to be taken care of:
1. Awning is bowed (20 ft)
2. Keyless entry don"t work
3. Screw found in the bottom of the frig...can't see were it went or come from?
4. One cabinet door warped (about 3/4 in. athe the bottom
Last but not least!!!!
5. 30 amp main has tripped 4 or 5 times at the same camp site the old trailer was at with the same things on....only difference is the A/C is 15k vis 13k..?
Service tech due out tomorrow will let you know how it goes....all inputs are welcome and needed.
Service techs made it out...took pictures of the awning and cabnet door, had the wrong 30 amp breaker? Took the door apart looking at the Keyless entry...as of now nothing fixed just wrote up and pictures made.......hummm?
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-20-2011, 06:31 PM   #14
tbritt's Avatar
Thumbs down
16 days now and it's not getting any better no one has been back and no calls the dealer has not answered my voice mails. Not the Black tank is not dumping......the handle does nothing. We're at the park that we manage so we have restrooms to use but you pay this kind of money for these things why can't you get the support you need.
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-20-2011, 07:33 PM   #15
grhodes50's Avatar
Try contacting Prime Time directly. See if the parts have been ordered. Maybe they can OK another repair shop in your area that will stay on top of things.
Good luck.
Gary & Trish
2018 Nights Camped - 5
Old 04-20-2011, 07:35 PM   #16
Location: Canandaigua,New York (The heart of the Finger Lakes)
Sounds like Prime Time has the same problems as the other Forest River Campers.....Oh well, thought with different manufacturing technologes they might be better. Seems as more and more are purchased (Prime Time)they are showing alot of the same problems as other manufactures. Sorry that your having problems. As was mentioned alot of new campers have these same problems. hang in there !
BigRed is offline   Reply With Quote
Old 04-20-2011, 07:47 PM   #17
grhodes50's Avatar
The one thing that I have confidence in Prime Time over others is their construction. Hopefully their trailers will not have some of the leak issues, including delam. Those problems are not really widespread, but they do seem to happen more often than they should. Only time will tell.
Most of the problems that we are having are on items found in other trailers, water heaters and so forth. So yeah, your right. We're going to have those same problems as everyone else.
The one area Prime Time really seems to out shine all others is their customer service. If you contact them directly, your problem will be dealt with quickly and correctly.
Gary & Trish
Old 04-20-2011, 08:12 PM   #18
Your are RIGHT-ON with service they provide. (Second to none). I just thought maybe even the little stuff would be better. Been having an eye on one of there 5er models for an up-grade in a year or two. Just dont want them to get like the others when there customer base gets bigger and bigger! I like the fact "RVguy"- the boss, roams the forums. - Beautifull grandson by the way "grhodes50"
Old 04-20-2011, 08:14 PM   #19
tbritt's Avatar
Hope your right, did use the contact web site but seems like each day brings on something different, the tanks drained twice since we set up but today nothing on the "Black" gray is ok, but very worrysome.
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-20-2011, 08:29 PM   #20
WJC
Hang in there, I had a few problems on my Tracer 3000 BHD, most recent I found my tires hitting the wheel wells. I talked with Brandon York from customer service who sent larger equalizers to my dealer who installed them. Used the trailer on a three day trip and had no problems with the tires!
WJC is offline   Reply With Quote
