Old 04-13-2011, 07:57 PM   #1
tbritt's Avatar
9 Days Old - still working out the bugs
Been it the new 303RK for 9 days now and have a few things or issuses to be taken care of:
1. Awning is bowed (20 ft)
2. Keyless entry don"t work
3. Screw found in the bottom of the frig...can't see were it went or come from?
4. One cabinet door warped (about 3/4 in. athe the bottom
Last but not least!!!!
5. 30 amp main has tripped 4 or 5 times at the same camp site the old trailer was at with the same things on....only difference is the A/C is 15k vis 13k..?
Service tech due out tomorrow will let you know how it goes....all inputs are welcome and needed.
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 04-13-2011, 08:13 PM   #2
sherdep's Avatar
#3 - screws in the bottom of the fridge - I havent found those in the fridge but probably was left there from when the camper was put together cause I have found screw's in the water heater area and under the table seat ends on my unit during delivery.
#4 is the door actually warped or just not sitting flat - could just need a hinge adjustment - better to let them break the hinge then you since it is under warranty
#5 tells me it is the campsite not the trailer if it triped with the old trailer and new trailer.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-13-2011, 08:41 PM   #3
tbritt's Avatar
Nope the door IS warped the hidges are in line... same camp site with both trailers we're the camp managers so we have the 1st site,it the trailer 30 amp triping not the service.
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-13-2011, 08:46 PM   #4
sherdep's Avatar
ok on the door - guess a new door is in store for you
Just means it is back feeding into the trailer and blowing your breaker instead of the one at the post.
To test the theory then - take the camper to another site and see if it trips there - sounds to me there is a power issue with the 1st site - reason why I say that is cause it cant be coincidental that both campers blow breakers on the same site.
Old 04-13-2011, 08:49 PM   #5
grhodes50's Avatar
Sorry to hear about your problems, but they do sound like typical new trailer issues.
I agree with sherdep about the screws. I have found them lying around in new trailers before.
Too bad about the cabinet door. My previous trailer had the same issue.
The keyless entry is a great idea that I really like. Unfortunately, quite a few of us are having problems with it.
My last trailer also had a problem with the breaker tripping. Same campground, same trailer, sometimes it would, sometimes it wouldn't. I blamed it on the campground. So far my 303 RKS hasn't had that problem at that same campground. The larger AC may draw just enough to make the breaker trip whereas your previous trailer with the smaller AC didn't. I have read where people say they have to shut down the water heater to run the microwave and so forth, so it's not an uncommon problem.
I'm sure PT will help solve your problems. Hang in there and good luck.
Gary & Trish
2018 Nights Camped - 5
Old 04-13-2011, 08:59 PM   #6
tbritt's Avatar
nope the first trailer never triped...
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-13-2011, 09:03 PM   #7
sherdep's Avatar
then I mis-read your statement then - I thought you meant the first trailer also tripped the breaker as well - no worries
I bet the issue is because you are pulling more with the bigger A/C unit and most likely something else is on like the water heater or converter is drawing more then the old one since it probably is a larger trailer.
just throwing that out there
Old 04-13-2011, 09:04 PM   #8
tbritt's Avatar
Think I found where the crew came from....look at your frezer door and see if there two screws on the bottom hedge? if so mine is missing one...looks to be broken off!!
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-13-2011, 09:08 PM   #9
tbritt's Avatar
Just what I was thinking but some people in the park say the difference between the 13k/15k is not that much....maybe a weak breaker?? You know new is not always good
2012 GMC 2500 HD
2011: 365
2012: 365
Old 04-13-2011, 09:15 PM   #10
grhodes50's Avatar
I just went out to check and yes, there are two screws on the bottom freezer door hinge.
Gary & Trish
