First, this thread is NOT at all meant to be a b___h session about our Prime Time product, nor do I hope it turns into one. We are actually over the moon happy with our 295RST. We just love it.
With that being said a number of issues have come up and I dropped it off back at the dealer yesterday. Luckily it is good timing as we are unable to use it for a few weekends anyway.
1. A leak in the water system. Somewhere under the floor and likely in the bathroom area. On our first trip we noticed the pump cycling more than it should which told me there likely was a leak. It was cold that first weekend (not freezing, just cold) and I didn't have the chance to look closely. On our next trip I finally saw water dripping out of the expanding foam. To mitigate it we only turned on the pump when it was needed. On our trip last weekend I hooked up to city water to test the system and the leak materialized much worse. Pretty quickly the underbelly filled up and I had to poke a hole in it to drain. The leak is not above the floor anywhere as near as I can find.
2. Either the filler tube is kinked or perhaps the breather is tube is plugged because we cannot fill the onboard tank more than 1/3. I suppose with the leak that's a good thing
3. The kitchen slide is rubbing along the bottom edge closest the door and the black fabric wrap is being torn underneath.
A few other misc fit and finish issues, nothing individually major.
My dealer just called me and went over everything so there was no misunderstanding.
Just FYI for other 295RST owners out there to keep an eye out for similar issues.
