Old 04-03-2015, 06:09 PM   #1
A Much Needed Tracer Modification - Dinette Table
I haven't taken the time to 'give back' to the forum as much as I've benefited over the years, so when I tackled this easy project (2-3 hours) I thought I'd grab some pictures and pass along.
The Tracer U Dinette has metal frame tubes that are positioned perfectly for you to slam your knees into the corners every time you slide into the booth - OUCH! This was an easy modification to do yourself, with a little patience and care.
After drawing a template of the cut away curve, I drew the cut line on all eight surfaces, and used a Dremel metal cut wheel to chop the corners along the lines. Then, I switched to a grinding wheel to clean up the metal, followed by sand paper to smooth. Lastly, some black touch up paint was applied on the cuts to make it look OEM. VOILA! No more banged knees.
Prime Time - if you make this mod. in future models, I want credit Happy Trails Everyone!
Name:	Tracer Table_01.jpg
ID:	72980   Click image for larger version
Name:	Tracer Table_02.jpg
ID:	72981   Click image for larger version
Name:	Tracer Table_03.jpg
ID:	72982   Click image for larger version
Name:	Tracer Table_04.jpg
2013 PrimeTime Tracer 3150BHD 'Ethel II'
2002 Salem 30BHSS 'Ethel I' (retired - RIP)
Hensley Arrow Hitch
2004 Dodge 2500 SLT Crew Cab 4.1 Ratio
Smiles and Miles
lcsolutions is offline   Reply With Quote
Old 04-03-2015, 06:18 PM   #2
Looks real great.The only thing that would make it better,IMHO,would be to get some of the edge trim to slip over the ends of the metal.I wouls still find away to bang and cut myself.
DaveandSue is offline   Reply With Quote
Old 04-04-2015, 06:50 AM   #3
Toy-aholic
I'm waiting for PT to pick up on my 3rd leg idea
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 04-04-2015, 03:16 PM   #4
EXGTM - that's beautiful; how did you mount the legs on the slide floor without penetrating? Looks great!
Hensley Arrow Hitch
Smiles and Miles
Old 04-05-2015, 06:42 AM   #5
Toy-aholic
same way the factory did...just ordered a complete leg kit with the same screws
cat, modifications
