Old 08-06-2017, 02:43 PM   #1
Ac
We have just come back from another great week end of camping. After 35 nights out since the 1st of April, the 380MBH has performed perfect. I do have one question tho. While in the basement I felt a great flow of AC coming from under the stairs. This is where the furnace is located. I wonder if I insulate this area if it would cause complication down the road when the furnace is running? Thanks for the info
Frank and Janet Henn
Brandon Ms
2017 Crusader 380MBH
pushing a 2007 Dodge
fhenn is offline   Reply With Quote
Old 08-06-2017, 07:10 PM   #2
rracer5's Avatar
Yes. The louvers in the wood on the step risers is the return flow for the furnace. If these are blocked there may not be enough air to the furnace causing it to overheat and shut down.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-07-2017, 11:43 AM   #3
Thanks, but I was thinking of insulating the basement wall but that could also take away the heat in the basement during our winter season. Thank you for you advice.
Brandon Ms
Old 08-12-2017, 05:11 AM   #4
I took the grills off and put 1/4" neoprene on the back and reinstalled. Made a big difference in the coach.
Of course they will have to be removed before using the furnace.
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
