Old 07-06-2012, 05:42 AM   #1
TTNewbees's Avatar
AC amps
Hi all,
I am going camping with some friends at a farm in Iowa this weekend. My friend got there last night. He said where my unit will be at has a 20 amp breaker.
Should I run fridge on gas?
Is 20 amp enough to run A/C in 100 degree heat?
If not, may have to bail on this as this metal box gets real hot in that temp.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 07-06-2012, 05:58 AM   #2
Herk7769's Avatar
Fridge on gas will help.
Yes you can run the ac on 20 amps but turn off every thing else when you run it.
Turn off the ac when you need to use a ac item like coffee maker or microwave.
Do not put water heater on ac if you have that feature.
Make sure it is 20 amp circuit and not 15 amps.
Originally Posted by TTNewbees View Post
Hi all,
HAM CALLSIGN - KC3FFW
Old 07-06-2012, 07:04 AM   #3
TTNewbees's Avatar
Running my fridge and A/C on 15 amp now from my garage plug, however it's only 84 now.
Does amp go up when it gets hotter/ more demand?
Yesterday evening I wasn't able to run A/c on same plug and now running both.
One difference is yesterday I was plugged into an extension cord. Is it more demand when it's hotter or extension cord playing a factor and tripping house breaker?
Thanks herkulator!
Mike
2012 Lacrosse 303RK
Old 07-06-2012, 07:29 AM   #4
sherdep's Avatar
the hotter it is the more demand there is - makes the flow of electricity work harder.
if you run it off of a extension cord make sure it isnt one of those chincy one's which are usually 14 gauge wire and the feet of the cord makes a diffrence in the wire size as well - it could get hot and melt the cord and cause a fire which could be bad.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-06-2012, 08:29 AM   #5
sail2liv's Avatar
volt/amps
Post went before done
Hot water heater-11-12 A @115V
Basic Camper 3 A @ 120V
15000 a/c 16-18 A @ 109V
Micro wave 9-10 A
Misc Light plugs as used
ceiling fan lights/speed
slides/awn when in use
jacks
If battery down basic camper will be higher....
15000 a/c fridge basic camper = 18-21A on 100 degree day
this number can go as low as 14 A when camper cools down....when plugged into house 20 A I feel quailty plug adapter to see it more than barely warm....also feel plugs at camper and surge guard.....without a meter to tell you current flow, you should run fridge on gas....as a/c and basic camper will always be there.....
Good luck feel the plugs......
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 07-06-2012, 08:32 AM   #6
sail2liv's Avatar
Thermostat
One other thought.......turn fan only to high setting....and leave it on high
then turn a/c to temp that it won t cut on and off.....that way you eliminate some of the high starting loads.....
