Old 07-05-2015, 12:20 PM   #1
AC unit error code e7
Have a spartan 1239 toy hauler .
AC units quit working and control panel shows error code E7. Outlets that are not gfci are not working. Plugged into 50 amp and power surge proctor shows all ok. Microwave isn't working either .
Checked all breakers and fuses and all look ok .
Any suggestions????
Cdw03 is offline   Reply With Quote
Old 07-05-2015, 12:34 PM   #2
Adh203's Avatar
E7 is loss of 120 power with all that's not working possible loose lug on main breaker or bad transfer switch. Do you have same problem with generator running?
Adh203 is offline   Reply With Quote
Old 07-05-2015, 12:48 PM   #3
Same result with generator running and 50 amp unplugged.
Old 07-05-2015, 07:52 PM   #4
rracer5's Avatar
Sounds like you've lost 120v on one leg. I had that problem once a a CG. Plugged into their 50 amp receptical and only half of my trailer worked. I used my 30 to 50 adaptor and plugged into their 30 amp & everything worked. Turned out the CG had a bad breaker in their panel. As mentioned above, you may have a loose connection somewhere from your transfer switch to your main breaker.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-06-2015, 01:37 PM   #5
john1345's Avatar
loss of ac power
ditto on all of the above.
John & Marianne
2013 Berkshire 360QL
john1345 is offline   Reply With Quote
Old 07-06-2015, 03:39 PM   #6
jmgllt's Avatar
E-7
Front A/C would not work and rear would turned out to be a tripped breaker to the front AC
jmgllt is offline   Reply With Quote
