Old 07-17-2014, 03:35 PM   #1
Adding AC to 3150
We are thinking about adding a second AC unit to our Tracer 3150, putting it in the bunkhouse. We live in Texas and unless it is winter (which is scheduled for a Tuesday in February most years), it is murder hot when we get to the campground. A friend who had a similar bunkhouse said he added one and ran a wire molding to the back wall and had a 15 amp inlet (like this one: that he plugged in with an extension cord. Most places I go have a 15 amp plug. I'm seeing ac units that run 13 amps. Anyone done this? Seems a lot less hassle than switching out to run 50 amp. Seems a good use of the bunkhouse vent, which I don't use, but have to keep a vent pillow in to keep the boys asleep past sunrise.
Any thoughts? I've seen a 3150 with a second unit but it didn't belong to the person who was camping in it (borrowed from a brother-in-law) so they didn't know anything. Any reason not to do it?
Bauer Camper is offline   Reply With Quote
Old 07-17-2014, 03:58 PM   #2
TURBS's Avatar
You need to use 20 amp wiring and thru wall plug.
Most camp grounds have a 20 amp plug in.
Most a/c unit take up to 19 amps to start then run at about 14 amps.
Old 07-17-2014, 08:13 PM   #3
irishrv's Avatar
I'd want to know the framing was there around the vent to support the ac.
2014 295rst champ te
2009 2500hd GMC d/a
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 07-17-2014, 08:21 PM   #4
Plain Old Member
Framing shouldn't be too much of an issue. Some that have done it, just add blocking if necessary once the vent is removed. Otherwise, don't we all walk on the roof to clean and inspect? And I'd bet none of us are even close to the 100 lb max weight of an AC.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
