Old 05-31-2014, 09:25 AM   #1
Adjustable ceiling vent for AC
There are a few things I'm surprised aren't standard equipment. One of these is adjustable ceiling vents for the AC that can be closed/adjusted. It looks like this is a common change people make on their units.
Two questions:
1. The current ones I have don't close, they only swivel. They are 7 inches in diameter, 1 1/8 collar, and 4 3/4 opening. I see there are several companies making after market units. Does anybody recommend one over another and know they will work on my Crusader?
2. How do you remove the ones already installed? I glanced at it and it isn't immediately obvious to me. There are three little notches/holes around the edge -- that may be involved in the removal process.
Any tips appreciated.
2014 Crusader 296BHS
2015 GMC 2500HD Denali
kohai is offline   Reply With Quote
Old 05-31-2014, 02:56 PM   #2
another_newfie's Avatar
To remove the vents just carefully pull them (you are removing the piece the swivels not the entire fixture). If you are gentle they won't snap.
A tip, while they are off, get some foil tape and seal the gaps. A lot of cool air escapes back inside the roof if there are gaps.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 05-31-2014, 07:25 PM   #3
Send a message via MSN to Tiggerdad
Check with "Dwin.corp. I purchased Model 8840 adjustable vents for my Crusader. They will open/close and swivel. They have lot's of neat items
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is online now   Reply With Quote
Old 07-21-2014, 08:12 PM   #4
I wanted to correct my bad info above for the archive. The collar is 1.5" and the opening is 4.75".
vent
