Old 08-21-2013, 08:28 PM   #1
Another Coleman Roadtrip grill conversion ??
I've been reading thru the different ways to convert a Coleman Roadtrip grill to use the low pressure outside connector on my Jayco Eagle Superlite. Most of the solutions discuss ways to remove the OEM Coleman regulator & connect a line directly from there to the onboard RV connector. Here's my question....Has anyone attempted to reroute the outside connector to the high pressure side of the RV? Wouldn't it be better to retain the Coleman regulator & just supply high pressure to it? I realize that this could be done very easily with a separate propane tank but, if your RV storage is as full as mine, carrying an extra propane tank would require leaving something else home. It shouldn't be too difficult to install a "T" into the high pressure side before the RV regulator and then attach the outside connector to one leg of the "T". Sure there would be fittings/adapters to purchase but, on the plus side, the grill would still be useable with the 1 lb cylinders if ever needed. Any thoughts?
larryc7777 is offline   Reply With Quote
Old 08-21-2013, 09:02 PM   #2
SYE
SYE's Avatar
Whjat I did with my Coleman roadtrip grill is I bought this kit from camping world for 45 bucks and called it a day!! They go on sale for about 45 bucks different times of the year. I think i BOUGHT MINE IN jAN OR fEB
Stay Flow Plus - Mr. Heater F273735 - Propane Hoses and Adapters - Camping World
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 08-21-2013, 09:03 PM   #3
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
well written Larry, I have asked myself this same question over and over, I looked for the T in websites that sell propane fittings and have read about every item on these forums. so in the mean time I'll wait to see if someone replies and maybe a picture or two.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
Old 08-22-2013, 09:38 AM   #4
SYE
SYE's Avatar
Here are the pics of it
ID:	38419   Click image for larger version
ID:	38420   Click image for larger version
Scott & Vicki
2021 4 reserved
Old 08-22-2013, 12:35 PM   #5
Phat Phrog Phlunky
essness's Avatar
Sye, do you have to turn that bottle off (close the valve) to connect and disconnect the grill line?
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
Old 08-22-2013, 12:44 PM   #6
SYE
SYE's Avatar
I do not. It works great and it allows me to use the grill regulator and not the campers
Scott & Vicki
2021 4 reserved
Old 08-22-2013, 12:53 PM   #7
Phat Phrog Phlunky
essness's Avatar
Last question, I hope does the hose end that goes to the bbq have the same thread as the 1lb bottles?
Thanks Sye, I owe ya a drink next year
2014 Raptor 27FS
igkra.com
Old 08-22-2013, 12:57 PM   #8
SYE
SYE's Avatar
Yes it does!!
Scott & Vicki
2021 4 reserved
Old 08-22-2013, 12:58 PM   #9
SYE
SYE's Avatar
Yes it does!!
I have actually switched grills now , I am now using a Webber Q200, using the same hose and valve.
Scott & Vicki
2021 4 reserved
Old 08-22-2013, 06:05 PM   #10
Now that's what I'm talkin' about!! Nice find Sye Right now Camping World wants $75 for the kit. Is the kit from another manufacturer? Campco? Or 1 of the other manufacturers?
Old 08-22-2013, 06:58 PM   #11
SYE
SYE's Avatar
Mr Heater is the manufacturer of this product, I am sure you can find a cheaper one, I bought mine in the off season and it was on sale for 45 I think it w2as on sale at the end of April I think it was their easter sale
Scott & Vicki
2021 4 reserved
Old 08-22-2013, 07:34 PM   #12
Amazon.com has the 3 port brass T for $28.28 - Camco part # 59133 and the hose for $23.59 - Camco part # 59043. The description and pictures look identical to what Sye has, so I ordered them. After I get them I'll post if they fit properly.
Old 08-22-2013, 08:32 PM   #13
Phat Phrog Phlunky
essness's Avatar
Amazon kit, Camco# 59103 $47.23 and free shipping
2014 Raptor 27FS
igkra.com
Old 08-22-2013, 09:12 PM   #14
I saw that one but I needed the 90 deg. 3 port fitting in order to easily connect to the oem high pressure pigtail. Free shipping here too
Old 08-22-2013, 09:48 PM   #15
SYE
SYE's Avatar
I honestly think I bought mine in Late Oct or Early Nov so I would have it for the summer. I had over 100 dollars and it was free shipping as well. Did the one on Amazon come with a hose too.
Scott & Vicki
2021 4 reserved
Old 08-23-2013, 05:34 AM   #16
Instead of purchasing the T and hose as a kit, I found them separately on Amazon. The hose is 12' long with male & female 1-20 threaded swivel fittings(same thread as the disposable bottles). The T appears to be identical to the one you have except that the in/out propane tank fitting locations are reversed. Also, this one uses the external type 1(?) threaded connectors instead of the internal threaded tank connector. I'll know more in about a week when it arrives.
Old 08-26-2013, 07:45 PM   #17
Well my parts arrived & I installed them today. I had to rotate the bottle 90 deg to maintain the proper angle for the oem connector and I also had to move the oem dual stage regulator to gain more clearance to connect the 12' propane hose to the top of the T. I had planned to move the regulator anyway because I wasn't happy with the way that the feed hose at the bottom of the regulator was forced to the side by the curvature of the tank. Anyway, I checked for leaks after installation and had a couple of bubbles at the 1-20 fitting at the top of the T. A little additional tightening of the knurled fitting nut fixed the problem. This afternoon I sacrificed some steaks to the propane god & everything worked great. The only PITA is cleaning the grill afterwards. I sprayed the grill grates with pam but next time I will spray the area below the grates also.
