Old 08-26-2012, 09:19 AM   #11
J_KHawthorne's Avatar
Originally Posted by murry52 View Post
Purchase Michelin Tires, balanced and filled with Nitrogen your problems will end. Always monitor Tire Pressure!
I was unaware that Michelin made ST tires! Where did you get them???
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 08-26-2012, 03:47 PM   #12
RattVader's Avatar
ROAD RIDERS Man,I don't want to hear that. Same brand here! Although I have roughly 6k on those tires and no issues yet.We plan one more trip in Oct. to WDW and that will be by the time we get back roughly another 2k.Again we have not had any issues to speak of.Would you mind my asking what psi you were running at the time?
Steve & Sue
2011 Crusader 320RLT
2008 Dodge Ram 3500 (CTD) DRW 4x4
RattVader is offline   Reply With Quote
Old 08-26-2012, 04:49 PM   #13
jtad's Avatar
80 psi.. checked about an hour before the first blow out.. and checked the morning of the second. all tires checked with a thermal gun at each stop also... no reason for this other than the tires are a POS... I was told by my tire guy after he did a lot of research that ST tires are not rated for how many miles they can go. but by how many "duty cycles" they are put through.. and that most ST tires were good for 6,000-12,000 miles or changed every two years.. depending on duty cycles....
2011 Cursader 298 BHD
2012 F-250 FX4 6.7 Power Stroke
B&W Companion Hitch
Days Reserved for 2012: 39
jtad is offline   Reply With Quote
prime time
