Old 07-31-2013, 11:23 PM   #11
RossandDonna's Avatar
I also have a 2012 290RLT and I am thinking of upgrading to a ST/225/75R15 load range E tire. Was there any problem with the wheels being able to handle the 80 PSI of the load range E tires? Do you know what PSI your factory wheels are rated for?
2012 Crusader 290RLT
2013 F350 Lariat Crew Cab DRW 6.7L Diesel
RossandDonna is offline   Reply With Quote
Old 08-01-2013, 05:26 PM   #12
on_the_bayou
PrimeTime's Avatar
My original tires were ST/225/75R15 Load Range D Cold 65 psi.
I weighed the truck and camper before we left on our trip.
Truck only
Front 4380 Rear 3280
Truck and Camper
Front 4380 Rear 5100 Camper 8820
New tires ST225/R7515 Load Range E cold 80 psi
I did not have problems with the new tires 80 psi.
2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
PrimeTime is offline   Reply With Quote
Old 08-26-2013, 07:14 PM   #13
As we started our second year with the Crusader we were just 80 miles from home and the LF tire on the camper blew. We only had a couple thousand miles on the camper. It was a belt separation which was verified by a dealer. The company promptly issued a check to cover the tire after I had someone in their network verify the tread and verified it was a belt failure. The company could not find a retailer any where near north Florida so I went to a CW and changed both tires on the axle. We were next in Jasper, Canada and I noticed unusual wear on the insides of both rear tires. We went to a Canadian tire store and purchased two new tires. All they had were LR E. We're now almost back in the state and have no trouble through the thousands of miles through north Canada and Alaska, even with their awful roads. I have put maxxis tires on my other camper and was extremely satisfied. I had much better luck with them that the marathons. The last set of marathons produced three blowouts and over $8K of damage in two incidents. My insurance covered the first damage and Goodyear covered the second damage along with a refund for the set of tires. I can't over emphasize the importance of checking tire pressure and lug torque after changing a tire.
pryner is offline   Reply With Quote
Old 08-27-2013, 05:48 PM   #14
07 ThunderRoad's Avatar
I have noted that Prime Time likes the SenDel aluminum rims. The max tire pressure is on the back of the rim. Here is the SenDel link.
Sendel Wheels There is a size - pressure chart on the web site.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 08-28-2013, 12:05 PM   #15
Tire pressure rating
Several months ago I was considering going to a load range G on my 290RLT. I currectly have 16 inch load E on the trailer with 6 lug rims. So I called Sendel and asked them if my current rims would handle the 100PSI rating of the G range tires. They told me that on their rims, if there are 6 lugs the max PSI rating is 80 PSI, 5 lugs is 60/65 PSI, and the 8 lugs is 100PSI. If you have 5 lugs, you could go with the load range E tires but you would probably have to keep the PSI at 65psi or below and not 80PSI. If you have 6 lugs you could inflate to 80PSI.
Crusaderguy is offline   Reply With Quote
Old 08-28-2013, 12:22 PM   #16
NELA
Weezer's Avatar
This being our first long trip (NE Louisiana to Pigeon Forge TN) we're thinking of upgrading our tires to E rating.
Yes, the tires were fine for the trip, but reading about all the failures here gives me restless nights.
We stopped every hour or so and checked the tires, checked pressures, checked for torque on the lug nuts, and felt the hubs (per OC's recommendations) But...
We happen to have a new good friend who is a close neighbor, is an RVer, and just happens to own a tire/service shop.
I foresee, in the not so distant future, him getting to sell and install 4 new tires for us.
A tire failure can be a trip killer as well as dangerous. I figure upgrading is a no brainer.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-28-2013, 12:28 PM   #17
Herk7769's Avatar
Additional info here:
Things to know about trailer tires
HAM CALLSIGN - KC3FFW
Old 08-28-2013, 12:40 PM   #18
Herk7769's Avatar
I missed where the tire pressure chart was on their web site. Their site has a LOAD (weight) rating, not tire pressure. Also my rims also have a weight rating (not pressure) stamped on them.
I also am concerned about "maximum inflation pressure" on my rims and had discussions with the wheel engineer at the Goshen rally who confirmed that the wheel pressure rating has a relationship with the rated load (weight) stamped on the rim; but that relationship varies by wheel design and tire bead angle.
He also stated that the stem selection also places limits on the maximum pressure that can be placed on any given rim. http://www.techtirerepairs.com/tech_...0Issue%202.pdf
Old 08-28-2013, 06:54 PM   #19
I was talking about the aluminum rims that SenDel makes. The max pressure is cast on the back of their rims.The size - max pressure - load are on the chart for that rim on the web site. RossandDonna's question was about the rim. They know how to read a tire side wall.
Old 08-28-2013, 07:31 PM   #20
Herk7769's Avatar
I wonder why they don't do that for their steel rims...
I was also talking about rims...
tire
