Old 08-03-2013, 02:54 PM   #1
RollingDownTheHighway's Avatar
Antenna
I'm currently camping and I'm unable to rotate the tv atenna. Is there a trick to it? Lol
I have a 3200 bht, I pulled the plate down but I can't spin it in either direction.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 08-03-2013, 03:09 PM   #2
You have to crank it up first. Then it should rotate.
Old 08-03-2013, 04:46 PM   #3
Lol it's cranked up, I just can't turn it, though I'm getting channels,
Old 08-03-2013, 05:26 PM   #4
wfmdfm's Avatar
On ours I need to pull down on the round dial about a 1/4 of an inch before I can turn it.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 08-03-2013, 05:53 PM   #5
Maybe Yogi Bear is standing up there holding it stationary. (This time I am trying to be funny.)
Old 08-03-2013, 09:42 PM   #6
VinceU's Avatar
Try a "dry lube on the rotary joint on the roof.
Old 08-03-2013, 09:59 PM   #7
I just bought a 230FBS and tried to rotate the antenna and mine won't rotate either. It's cranked up and I pull down on the "disk", but it will not rotate. Called dealer and he felt there would be some caulk in a wrong place. Waiting for a nice day, my wife available and me on the roof to see what is wrong as she tries to turn it. In the meantime I'll be watching to see if any solutions show up here.
Klemintine is offline   Reply With Quote
Old 08-05-2013, 12:03 PM   #8
I went up on the roof and DW tried to turn antenna. won't move. As she held the disk down I was able to rotate the unit when I was on the roof. Actually caulk had "spilled" over against the antenna base when it was poured on the mounting flange to cover the screws, etc. Use a knife to cut it free and remove enough caulk so it does not touch the antenna base. This should have been part of dealer prep.
Old 08-05-2013, 12:26 PM   #9
Ripley711's Avatar
If the antenna is made by Wineguard, the manufacture suggests using a spray silocone to lubricated the turntable of the antenna base and the gears. To do this spray underneath the cast aluminum plate so that the entire perimeter is lubricated. Then remove the plastic cover that is located on the standing post on the turntable. Give a shot of silicone here as well. Now you will see a black plastic gear if you look down over the top of thea antenna, spray this as well. As Marvin mentioned if there is caulk holding the unit from turning this is an easy fix. I have just bought a Salem Cruise Lite and had to rebuild the antenna due to a bent rotating shaft and leaking due to a forgotten seal at the factory. The factory servce told me how to lubricate the unit and said this has to be done twice a year.
2012 Ram 2500 Larame Cummins
2018 Rockwood 8299BS
2014 Salem Cruise Lite 261BHXL (Sold)
2016 Camping Nights = 32
2017 Camping Nights = 14
Ripley711 is offline   Reply With Quote
Old 08-05-2013, 02:01 PM   #10
Well I'm back from our first trip and the antenna just wouldn't budge to save my life. I'll go up on the roof later on to see if something could be blocking it
Old 08-05-2013, 03:56 PM   #11
I had the exact same issue on my 2014 Lacrosse 327 RES. I had the dealer fix it when I took the unit back in following my first trip. Basically, for the new unit "punch list". Not sure what was done, but it turns freely now.
OakHillFarm is offline   Reply With Quote
Old 08-05-2013, 05:13 PM   #12
Be very careful spraying silicone on the roof. It isn't good for the membrane covering the roof.
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
antenna
