Old 02-26-2012, 09:49 PM   #1
Any other Lacrosse 296 owners?
Just curious about what size spring bars others have. My dealer set me up with a round bar Reese and friction sway control, but I think I'm going to get an Equalizer and not sure whether to get 1000 or 1200lb bars.
phone man is offline   Reply With Quote
Old 02-27-2012, 08:14 AM   #2
I have the 1000 lb bars and do just fine. Although I have to add water to fresh tank to get more tongue weight.
2014 Ram 2500 Laramie CC 6.4l Hemi
2011 LaCrosse 296BHS
autorot8 is offline   Reply With Quote
Old 02-28-2012, 02:20 PM   #3
I use 1000 Equalizer bars with my 318bhs and they work great. The 318 has 100 more pounds of hitch weight. You should be fine with the 1000 pounds. Make sure you get the 4 way Equalizer and not the cheaper 2 way. You could also buy the cams and turn your Reese into a dual cam system. You will not be satisfied with a standard Reese with friction sway bars. Especially with a 32-33 ft trailer.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 03-01-2012, 08:27 PM   #4
I have the dual cam 1200/12000 and although it's been ok, it hasn't been great. I found an older Hensley I'm cleaning up to use this summer.
mister_d is offline   Reply With Quote
