Old 08-07-2016, 10:49 AM   #1
Jlreeves's Avatar
Any owner comments? Briggs & Stratton P3000 Inverter Package with Parallel Cable
Looking for any pro/con comments on this unit. Seems to be reasonably priced and has the wattage I am looking for.
2017 PrimeTime Crusader 315RST 5th Wheel
2014 Chevrolet Silverado 2500 HD
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
Jlreeves is offline   Reply With Quote
Old 08-07-2016, 03:36 PM   #2
Moderators' Assistant
bikendan's Avatar
Please provide a link.
Normally B&S are loud.
Even their inverter generators are louder than other brands.
Are you going to use it in a campground or for boondocking?
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 08-07-2016, 03:42 PM   #3
bikendan's Avatar
And why would you go with this generator, when you can get the well-proven and cheaper Champion 3100w inverter generator?
Even the new 3400w version is cheaper.
Old 08-07-2016, 03:51 PM   #4
Jlreeves's Avatar
Should have specified in my post. Boondocking.
FROG # GA-0056-236
Old 08-07-2016, 03:52 PM   #5
Jlreeves's Avatar
I haven't seen that one in my search. Thanks for the lead. I will investigate.
FROG # GA-0056-236
Old 08-07-2016, 03:55 PM   #6
bikendan's Avatar
They are talked about constantly on RV forums.
On the other hand, have never seen anyone that had one of the B&S units, on any RV forum.
Old 08-07-2016, 04:02 PM   #7
Jlreeves's Avatar
http://www.electricgeneratorsdirect....or/p15081.html
FROG # GA-0056-236
Old 08-07-2016, 04:04 PM   #8
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
X2 with Bikendan. I would give a serious look at the Champion line of gens. Tractors Supply sells them for under $300 on the 3500/4000 watt models and just over that for the 4000/4600 models. The ones I have, have worked flawlessly for 4 years now. Five years on one unit.
Keep the oil changed and clean, fresh fuel [not ethanol garbage] and you will have no problems with them for a long time. My oldest unit [3500/4000] has over 1,100 hours on it and still cranks on the first pull, and yes I do have an hr meter on it as do all my gas motors i.e. outboards, lawn tractor, generators, aircraft. I'm anal about maintenance and oil changes.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 08-07-2016, 04:30 PM   #9
Taranwanderer's Avatar
Here's a good thread for you to read on the Champion:
impressed with Champion 3100 inverter generator
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-07-2016, 04:38 PM   #10
I will say this for the B&S as far as durability. I picked up the Craftsman 5600 during the Hurricanes here in Florida back in 2004. It ran none stop for four straight days. Since then, well, I sure have neglected it.
I try to start it when I think about it (out of site, out of mind). I can say at one point it went about 2.5 years forgotten about. Starting last year I began to use it more, just to use it with the electric hedge trimmer, pressure washer, air compressor, etc.......this was about once every two or three months.
That thing started every time, maybe not on the first pull, but it started. I just had the carb cleaned last month ( first service it ever had) outside ummm, bi-yearly oil changes, and a replaced pull cord, and now it does start on the first pull. I used it today just to use it.
I do Spring maintaince on my other gas powered engines before mowing season each year, and hopefully will start on the generator too.
Those are tough machines even when neglected, but are loud.....sound like a lawn mower !
2017 Forester 3011DS (On order)
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is online now   Reply With Quote
cable, inverter
