Old 07-31-2013, 04:53 PM   #1
Anyone else have this problem?
My outdoor shower on my 318 will not work on cold. Hot water comes without issue. This has not worked since I de-winterized. Any ideas? This is my 3rd year camping with the trailer.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 07-31-2013, 05:17 PM   #2
davidjb's Avatar
Weird, does the handle feel like its still connected? Maybe a broken shaft.
davidjb is offline   Reply With Quote
Old 07-31-2013, 08:20 PM   #3
rracer5's Avatar
Had the same issue with my HOT side when new. I decided to take a look myself (remove the access panel from under the bed) and found that the feed line behind the faucet was kinked. I had to cut the line shorter so that it wouldn't kink when trying to route it to the faucet. I had to purchase the special tool & clamps (Lowes) for reinstalling new clamps on the hose fittings.
But, then again, it could just be a piece of debris that became dislodged and is now lodged in the line or fitting. In either case, you'll need to gain access to the rear of the faucet to disconnect and diagnose.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
