Old 05-27-2014, 01:30 PM   #1
Anyone else having some trouble with Power awning?
my 2014 Tracer 2670. I have the power awning, im assuming dometic 9100? Unit is up at camp right now 1.5 hrs away so I cant look... anyways.. awning opens up fine..no issues... when I go to close it after a weekend of use when it gets more then halfway closed it seems to slow right down and has a weird noise to it, almost like it starts shaking a bit to close.. it closes fine but just seems to strain at the end...sometimes if I close it halfway and then open again, it wont do it.
I have one month left in factory warranty.. I hate to waste all he gas and time to pull it way down to my dealer for them to look at.. do you think its possible for me to call primetime and report it, and maybe take a video of it..and then when its at my dealer this fall then they can look and repair if broken?
yankeeslover is offline   Reply With Quote
Old 05-27-2014, 01:32 PM   #2
billster_ny's Avatar
Check your track on the camper for obstructions, bends or debris. When it closes, there is a slide that moves through the track. You might want to put some light grease in the track, just a little though.
billster_ny is offline   Reply With Quote
Old 05-27-2014, 01:34 PM   #3
iceblaze580's Avatar
Did you by any chance tighten the pitch knobs on it if you did loosen them up it should go away
iceblaze580 is offline   Reply With Quote
Old 05-27-2014, 02:01 PM   #4
I will check the track... and iceblaze, the knobs are loose.. it does sound like they need to be greased... but I cant be certain... where does one grease these? and what kind of grease? I don't want it attracting dirt and such.
Old 05-27-2014, 02:04 PM   #5
Mine did that too. I wiped the slides and the rod on the gas cylinders on each support with some WD-40, the problem went away.
OakHillFarm is offline   Reply With Quote
Old 05-27-2014, 02:04 PM   #6
Grease inside of the track, sides an back only where the insert slides. Dirt could become an issue over time unfortunately.
Old 05-27-2014, 02:11 PM   #7
Are you referring to the folding arms as slides? If so, there should be at least 1/16" gap between the sides of the arms where they interlock.
Old 05-27-2014, 02:29 PM   #8
B and B's Avatar
it is possible the awning fabric has moved to one end of the roller. That would cause the arms to misalign. See of the fabric is centred. This has and does happen to my AE Manual awning on my park model often.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-27-2014, 02:32 PM   #9
B and B, actually, If I remember, I think as it rolls up it does go a bit to one side, I don't think its perfectly even, but I don't remember.. is this an easy fix?
Old 05-27-2014, 02:37 PM   #10
If this has happened, extend the awning and slide the material over and make sure it is centered on the roller and then pop rivet thru' the side hem of the material into the roller on both ends.
Name:	Pop Rivet in Awning.JPG
awning, power
