Old 03-04-2012, 01:26 PM   #11
acadianbob's Avatar
Originally Posted by flyrotor View Post
My suggestion is to take it to a tire dealer. At times the seal can be leaking and just a dismount and remount can correct the problem.
Yep! Had that happen on a car once. They had some "rim sealer goop" that they put on the rims. Remounted the tires. End of problem.
But I would suspect valve stems or even a loose valve in the stem that might just need to be tightened or replaced. You would lose all of the air pressure in the tire but you can replace the actual valve without replacing the stem. I had a bad valve on one of my tractor tires; so replacing it fixed the problem. You don't want any weight on the tire if you try this so that you don't lose the rim seal. And of course you would want compressed air available to re-inflate.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-04-2012, 01:46 PM   #12
Thanks all. Definitely not temp related, since it was sitting in on site on site in a central coast California RV park :-) Lovely, temperate climate. Freezing? never happens :-)
Laura is offline   Reply With Quote
Old 03-04-2012, 03:00 PM   #13
acadianbob's Avatar
Yah, we only have freezing here between Oct 15 and May 15; the rest is good!
Old 03-06-2012, 10:01 AM   #14
We had a split in the side of on of ours, PT took care of it no problem. There may be a problem on the back side you cant see. Blown tires while towing cause a lot of damage to the trailer so be sure to have it checked out thoroughly. My first big purchase is to replace the factory installed tires.
HAARubicon is offline   Reply With Quote
Old 03-06-2012, 03:11 PM   #15
RossandDonna's Avatar
We had a similar problem with our tires. We had bad valves replacing the stems didn't work. The trailer was less than a week old so we took it to the dealer and they replaced the valves under warranty. So far all is well.
2012 Crusader 290RLT
2013 F350 Lariat Crew Cab DRW 6.7L Diesel
RossandDonna is offline   Reply With Quote
Old 03-06-2012, 04:09 PM   #16
shabbona north's Avatar
You can diagnosis the tire your self, get a spray bottle and fill it with 5% dish soap and 95% water, spray the entire tire and wait for bubbles. A slow leak will have very fine bubbles almost like shaving cream. If it appears on the side wall or thread with no apparent damage then your tire is not repairable. If however there's a leak around the stem or rim then the tire may be repairable. Bead sealer and a new stem should take care of it.
shabbona north is offline   Reply With Quote
Old 03-07-2012, 07:24 AM   #17
Check the rims... could be defective. If that's the case make dealer or factory replace them. Don't take the chance with sealant... IMHO not worth it.
grayfox is online now   Reply With Quote
Old 03-07-2012, 07:48 AM   #18
Originally Posted by crocus View Post
If they are Chinese tires, I would replace them. It simply isn't worth the risk of having a tire failure.
We replaced ours with Maxxis tires, and upgraded to a higher load rating while we were at it. The Chinese junk the factory put on were minimal at best.
It may seem expensive, but the alternative is far worse.
Hate to break this to you but those Maxxis tires you strapped on are not made here . By no means am I saying it's not better quality than some of the true no frills Chinese slave labor units out there.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 03-07-2012, 08:50 AM   #19
Herk7769's Avatar
I get this all the time. Every manufacturer has some or all tires made from countries around the world. The only way to tell is to LOOK at your tire's DoT code molded into the tire.
Here is some help figuring it all out.
http://www.tire-information-world.com/dot-location.html
Here is by Company
http://www.tire-information-world.com/dot-company.html
Note: Maxxis are made in China. LOL Even Pirelli has a Chinese plant.
Name:	Goodyear Marathon Made in USA 006.jpg
HAM CALLSIGN - KC3FFW
Old 03-07-2012, 08:53 AM   #20
amxpress's Avatar
Before upgrading to my 16" tires, my tires would not maintain pressure over time, especially while parked.
I installed steel valve stems which seemed to have corrected the problem.
While the tires were off, I also balanced them. I know it doesn't effect the air leakage, but they roll much smoother.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
