Old 03-11-2013, 08:13 AM   #11
Rick R's Avatar
Lots of information on this thread at Airstream Forums
Centramatic Balancers Update... - Airstream Forums
Rick R is offline   Reply With Quote
Old 03-11-2013, 08:18 AM   #12
extremebike's Avatar
Originally Posted by checca View Post
I found with my other trailers ( cargo and travel ). Balanced tires keep stuff from moving around in the trailer. They also tow better on rough roads or in weather. I was hoping to use the automatic balancers instead of getting weights added to the nice rims.
HI!
I agree about the merits of balanced trailer tires. I used bead balancing on the 19.5 inch TV tires and I am very happy. They can install the beads without taking the tire off the rim so it will be much easier to get it done.
The dealer rim balanced my trailer tires but they had to take the tires off to replace the tires for me so that was the easiest way to go. There are some huge weights on two of the tires and on both sides of the tire so it must have been really out of balance. Not good for the axles.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 03-11-2013, 08:46 AM   #13
wmcclay's Avatar
I have them spin balanced mounted on the axle. It balances everything rotating. They use stick on weights. You will notice a great difference. These tires are usually way out.
Wayne
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
