Old 03-09-2013, 06:00 PM   #1
checca's Avatar
Question Anyone using centramatic balancers?
I emailed the prime time factory ... But is anyone using centramatic balancers?
When I talked to centramatic, they said I needed 12 3/4" clear inside of the rim.
But the aluminum rims on my lacrosse 318bhs have a complex curve on the inside of the rim and I'm not sure I'm measuring correctly.
Anyone?
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 03-10-2013, 06:44 PM   #2
checca's Avatar
Bump?
Minooka, IL.
Old 03-10-2013, 07:04 PM   #3
VinceU's Avatar
Anyone?
I can fathom the purpose of the balancers but why bother with the expense? RV tires normally fail due to age or overload/abuse. Never heard of balance being a primary wear problem?
Old 03-10-2013, 07:34 PM   #4
checca's Avatar
I found with my other trailers ( cargo and travel ). Balanced tires keep stuff from moving around in the trailer. They also tow better on rough roads or in weather. I was hoping to use the automatic balancers instead of getting weights added to the nice rims.
Minooka, IL.
Old 03-10-2013, 08:05 PM   #5
VinceU's Avatar
I think I'd ask for back mounted weights, any advertisement that uses 4 color press (offsets) or more is very suspicious to me. As a trained Marine Engineer I find the website very sketchy and full of crazy claims. No offense meant here this just adds more weight to the un-sprung axles......
Agree "balanced tires"... just not sure these are as effective as claimed, also noted "one size fits all", read as design, and same price from 5" to 24" withing 10 bucks! Just wondering?
Old 03-10-2013, 08:45 PM   #6
checca's Avatar
I would agree, but I work in IT for a long haul trucking company, our trucks with them on the steer tires go 40% more miles, then the trucks without them installed. I know there are a lot of variables, between drivers, trucks, and loads. But the data is very consistent. i would hope the same results on my travel trailer and keep stuff from shifting around inside. I've used wheel weights on my cargo trailer with great success in the past. Since no one here has tried them, I hope the factory will get back to me.
Minooka, IL.
Old 03-10-2013, 08:56 PM   #7
I 'bead-balanced' my tires.
Seems to be a tried-and-true older method, and cheap.
All of the school buses and a lot of truckers use them in our area.
bakken is offline   Reply With Quote
Old 03-11-2013, 12:01 AM   #8
checca's Avatar
Was thinking about them too.
Minooka, IL.
Old 03-11-2013, 05:19 AM   #9
Witch Doctor's Avatar
I really do not understand why people do not balance trailer tires. When I bought my new Marathrons I was asked if I wanted them balanced I said yes. He said to me he thought he would ask because atleast 70% of people buying tires for there TT say no. They mounted the weights on the inside of the rims.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-11-2013, 08:02 AM   #10
When I messed up a tire recently, they asked if I wanted the new one balanced and I said yes, thinking that the old one was balanced by the factory. After that, the balanced tire seemed to indicate a consistently lower temperature on my TPMS compared to the tire on that same side on the other axle. (This could be other factors.)
I later realized that the tires are *not* balanced by the factory. I've had one other balanced since then and will continue to do that as I get the chance. They put weights on the inside of the rims (the stick-on kind).
Old 03-11-2013, 08:13 AM   #11
Rick R's Avatar
Lots of information on this thread at Airstream Forums
Centramatic Balancers Update... - Airstream Forums
Rick R is offline   Reply With Quote
Old 03-11-2013, 08:18 AM   #12
extremebike's Avatar
HI!
I agree about the merits of balanced trailer tires. I used bead balancing on the 19.5 inch TV tires and I am very happy. They can install the beads without taking the tire off the rim so it will be much easier to get it done.
The dealer rim balanced my trailer tires but they had to take the tires off to replace the tires for me so that was the easiest way to go. There are some huge weights on two of the tires and on both sides of the tire so it must have been really out of balance. Not good for the axles.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 03-11-2013, 08:46 AM   #13
wmcclay's Avatar
I have them spin balanced mounted on the axle. It balances everything rotating. They use stick on weights. You will notice a great difference. These tires are usually way out.
Wayne
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
