Old 03-07-2015, 02:38 PM   #1
Atwood Range Trouble
My Atwood model 2135 front burner literally "burns up" and melts the plastic sleeve in the fuel line. As it does this the only warning is a large yellow flame just before that plastic part melts. It seems that plastic sleeve is only 2" from the gas burner flame! Anyone else having this problem? Whe I order the repair part the service dept. said they sell several of these plastic sleeves. Appears to be a design problem.
volwing1 is offline   Reply With Quote
Old 03-07-2015, 08:37 PM   #2
Dave_Monica's Avatar
I had the same problem and talked directly to Atwood. They claimed that the manufacturer or dealer bend the front burner mounting bracket when they test propane line pressure at the cooktop. They sent me a new complete burner assembly and the problem appears to be solved.
Old 03-07-2015, 09:08 PM   #3
Thanks Dave. Yes I see the burner bracket is bent so much that it affects the gas flow. The burner is pulled about one inch away from the gas valve!
