Old 05-08-2015, 05:44 PM   #1
RollingDownTheHighway's Avatar
Atwood water heater - electric
Ok, first trip of the season with a new water heater in our tracer 3200bht and again it's only working on propane. I had it in electric for a half hour and nothing, I switched it to propane and boom it fires up and heats the water
Any suggestions on what to check?
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 05-08-2015, 06:00 PM   #2
Platokidd's Avatar
At times on my lacrosse I will lose electric hw. I would open the outside access door and wiggle the wires on the board. Upper right side I think.Worked every time for me so far. Might be worth a try?
Just curious as to why you had to change out your water heater so soon?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 05-08-2015, 06:11 PM   #3
I had the same issue last year and they replaced the element and it was working according to the dealer
Old 05-09-2015, 10:02 AM   #4
another_newfie's Avatar
If not loose wires my guess is your electric element is burned out. It's a easy DIY fix with the tool to remove the element. Takes only a few minutes.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 05-09-2015, 10:22 AM   #5
It's a new element, it was just replaced last fall due to the same thing
Old 05-09-2015, 10:27 AM   #6
10 secs with the electric on and no water in the tank and it's toast! Disconnect the wires from the element and check it for continuity. No continuity, it's gone also.
Old 05-10-2015, 04:54 AM   #7
Yeah I didn't even turn it on for about a half hour after hooking up and having the water on. I'll have to do some checking when we get home
Old 05-11-2015, 05:16 AM   #8
BBBlue's Avatar
I had the same issue in my Sanibel last year. Water heater worked on propane but not on electric. Checked element for continuity and it was good. Checked 12V/110V relay and discovered it was fried along with the wiring. This issue also blew part of the circuit board out. Was repaired under warrantee. Relay, wiring, and control board replaced resulting in a water heater operating on electric and/or propane.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
BBBlue is offline   Reply With Quote
electric, heater, water, water heater
