Old 04-07-2015, 06:13 PM   #1
awning trouble
Took out our 27bbs for easter wkend camping was quit a bit colder than we hoped for. Water line froze up in the mornings no big deal just crawled under with a heat gun and gently heated it, fixed. Everything else went great furnace kept us nice and warm. Opened awing for first time since this was our 1st trip with the trailer. One side of awing drops so low the door rubs it. push it back up and it drops back down. non power awing, think its a lippert. Any suggestions
m hill is offline   Reply With Quote
Old 04-07-2015, 06:41 PM   #2
bubbles's Avatar
Don't understand "push it up and it drops back down". Is it an A&E Dometic Awning? Each side rail has holes for locking the awning with a selected drop. Maybe a different animal than I am familiar with.
Old 04-07-2015, 07:33 PM   #3
Are you sure you unrolled it all the way? After you unroll it, you slide the two support rails toward the end of the awning until they lock into place. Then you raise the awning with the locking handles to the desired height. The only reason it would sag is if it was not extended all the way and/or the support rails were not slid forward and locked into place. Hope this helps.
2914 Tracer 2950BHS
Griswalds is offline   Reply With Quote
Old 04-07-2015, 10:12 PM   #4
Dave_Monica's Avatar
Is it a Solera awning by LCI... Solera¬ģ Manual Awning
Are you talking about the pitch adjustment on the awning arm not staying in place?
Dave
Old 04-08-2015, 04:37 PM   #5
Dave Monica it is a lci solera manual. What am i doing wrong?
Old 04-08-2015, 05:19 PM   #6
Have you looked at the bottom most video...shows the friction joint (@ 0.57) you adjust to have water run off. Is this your problem that the friction joint won't stay straight and the awning tills to that side?
Dave
Old 04-08-2015, 05:49 PM   #7
Sorry kinda new to this forum stuff. Dont know what you by bottom most video.
Old 04-08-2015, 06:09 PM   #8
Oaklevel's Avatar
He has a link to the video in his post I think it was #4.
Good Luck.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-08-2015, 06:27 PM   #9
Got it. Thanks. Seems like my friction joint doesnt have enough friction. Gonnahave to try and tighten that next time i open it.
awning
