So, still awaiting fix info on axles...PT is working with Lippert on issues... After reading a lot of info on axle problems, are the axles supposed to arc up or down? Mine arc down...3500lb axles have bad camber and have odd bounce while in tow...no were near limit at all on loading. Thoughts? TT is 2012 2910bhs tracer...
I have never seen axles cambered up..I have seen them cambered down and no noticeable camber at all but not cambered up. Are axles flipped? I have read about this happening before (not on PT's) over on RV.net.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
I build trailers at home as a sideline hobby. All axels are cambered up in center about 3/4 of and inch because you want toe in. When you add weight to a toed in axel they tend to flatten out slightly. If you have them toed out they wear tires on the inside quite a bit when loaded.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
The tires lean inward at the top while relatively unloaded...when traveling the back axle tends to bounce and tires wiggle in and out at the top...many co travelers have told me that it isn't right...we will see what PT and Lippert do...so far I am unimpressed with Lippert and maybe we should just put Dexter axles under...hehe...I know I want matching axles under it...
I evidently got the definition of cambered swithched. I meant upside down u not right side up u
Chamber
The angular relationship of the wheel to the road surface in the vertical plane.
Axels are typically built with a pre-determined bend in the tube that compensates
for the expected deflection under load. Ideally, the tire footprint will contact
the road evenly across the width of the tread.
2011 25 RL Wildcat
This sounds like a tire balance issue, have you thought about that?
Some others on the wildcat camper forum have had axle problem and they called lippert. And lippert was very good to them and replaced both their axles with hardware and all at no cost to them.
2011 25 RL Wildcat
