Old 11-15-2012, 06:48 PM   #1
Ddubya's Avatar
Battery connectors
I am installing a battery disconnect on my new 2013 290RLT and discovered several crimp terminals that are improperly crimped and loose. There were also two wires in a single terminal which attached to the battery which was also loose. I will use two terminals to replace the single one which should have been done by the installer.
I would advise everyone to check all12vdc crimp connectors for proper installation.
Ddubya is offline   Reply With Quote
Old 11-16-2012, 09:35 AM   #2
wmcclay's Avatar
Solder and heat shrink only way to go. Those connections in the battery box are exposed to highly corrosive gases. I make up a pigtail and make my secondary connections outside the battery box. Even a few 10ths of a volts greatly increases amp draw which equals heat.
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 11-16-2012, 03:45 PM   #3
Originally Posted by wmcclay View Post
... Even a few 10ths of a volts greatly increases amp draw which equals heat.
Wayne,
I often make solder connections too, but as you probably know, a "properly crimped" connection is gas-tight, so the corrosive gases don't get in.
Not to put too fine a point on it, but your statement I quoted above is incorrect. Resistance in the connection will actually cause a slight decrease in the amperage (proportional to the voltage drop). The heat is caused by the normal high current flowing in those circuits passing thru the resistive connection. P = I*I*R
Old 11-16-2012, 06:32 PM   #4
Ddubya's Avatar
I replaced and soldered several terminals today.
You would think that as many connections as are made on these RV's they would use the correct crimp tools.
Old 11-19-2012, 10:42 PM   #5
J_KHawthorne's Avatar
Thanks for the heads-up, Ddubya! Going to check this out first thing in the AM!
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 11-19-2012, 10:44 PM   #6
BTW, I hope you passed this info on to the good folks at Prime Time!
Jim & Kathy
Old 11-19-2012, 10:55 PM   #7
I took 3 years of electric shop in high school plus 2 more years of college when I thought I wanted to be an electronic engineer.
I was taught to make a good physical (load bearing) connection first (twisted wires, crimped connection, etc.) and make a good electrical connection second (solder).
So that is what I have been doing since 1972 and I have never been disappointed.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 11-20-2012, 07:09 AM   #8
Ddubya's Avatar
While soldering the connectors is an excellent hedge against current loss it is not practical in the type of assembly used by RV manufacturers. The use of a proper crimp tool and good electrical practices would aid in decreasing installation time.
Old 11-20-2012, 07:35 AM   #9
Trailer Trash
Good tight crimp on left, bad loose crimp in right
Cheap crimp tools on left, excellent ratcheting style crimper - the two on the right.
Then you have the skill level of the "professional" staff that wired up your camper.
Now you know why some wiring jobs last 30+ years and some fail 1st year. Even at the same company, it's a crapshoot with the quality of the wiring jobs. It really came down to who did the work. Some guys were good and some guys not so much. I used to be a traveling field service tech. One of my first questions back to the factory was........who wired it?
joelek is offline   Reply With Quote
battery
