Old 05-24-2015, 03:32 PM   #1
pattyinflorida's Avatar
battery cut off switch
We have a primetime avenger 21 rb and really love it. The tt did not have a cut off switch to disconnect the battery, so we had general rv install one. Worked fine till the other day. Can not get any battery power in tt. Took it camping anyway since we were using shore power. Any suggestions ? Also we have water runoff gutters on each side of the tt, but when the a/c is on the water runs down the awning. Is this a common problem. New to rving so need a little help.
pattyinflorida is offline   Reply With Quote
Old 05-24-2015, 03:51 PM   #2
PSUFan1's Avatar
Photo of the battery disconnect switch?
Tip the trailer backwards so the ac water drips off the back gutters
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 05-24-2015, 05:20 PM   #3
Don't have a pic of battery disconnect switch, but it is just a round knob and off is vertical and on is horizontal. It is installed directly on the front of the tt. It was installed by dealership and has been working fine. Thanks for your reply.
Old 05-24-2015, 05:36 PM   #4
Ford Idaho's Avatar
Switch is a basic disconnect, the lite has one like it.
I would suspect the cables are the problem unless it is the battery.
In any event you could pull the switch and clamp the wire ends together and then tape over the clamp.
Old 05-24-2015, 05:39 PM   #5
The battery works fine for the electric jack, but it is direct wired to the battery, just not getting any power to the tt.
Old 05-25-2015, 11:53 AM   #6
Jack power may come from the engine battery and you have a dead battery
rzrnaz is offline   Reply With Quote
Old 05-26-2015, 07:30 AM   #7
Wolverine 1945's Avatar
Our Flagstaff TT had fuses under the trailer tong,,,
between the battery & trailer ???
Had one of them blow once !!!
Wolverine 1945 is online now   Reply With Quote
Old 06-11-2015, 08:18 AM   #8
AvengerBob
Just disconnect
There is no need for that switch. All you have to do is disconnect the negative post on the battery when storing. It sounds like there is a problem with the switch. If so get rid of it and do above.
Check you battery and to make sure it is not defective. Your battery will charge two different ways. It will charge when you are connected to shore power. It will also charge when your 7 pin connection is hooked to your truck and it is running. However to do that you must have a fuse and relay installed in your truck that does that. You will find the location in your truck manual. For some reason Ford sells the the truck with the fuse and relay not installed. Mine was in a bag in the glove box.
I learned the hard way after battery went dead after storing for just three weeks. Luckily I strore it at an RV place and they informed me.
bob52 is offline   Reply With Quote
Old 06-11-2015, 08:22 AM   #9
AvengerBob
AC
Also on the AC dripping - that is because you do not have you trailer level. Do not have it tilted back as someone has said - it should always be leveled and that is important. It needs to be level (both ways) in order for your refrig and ac to work properly. When level you will not have that problem.
Old 06-11-2015, 08:29 AM   #10
I would keep the cut off switch, you need to use a multimeter to find out if the power is getting through the switch or not. There are reset-able breakers under the trailer you should look at to see if one has tripped. The reason i say to keep the switch is removing the cable from the battery can cause arcing, this can damage components in you trailer. A switch opens and closes the contacts much faster and reduces the amount of arcing.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
battery
