Old 07-17-2017, 05:55 AM   #1
Battery disconnect
I'm thinking that the battery disconnect should remove the 12vdc system. However when I pull my disconnect switch while plugged into shore power nothing in the coach shuts off. Can someone advise me what should be happening when the disconnect is pulled? Thanks
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 07-17-2017, 06:02 AM   #2
SilhouettePenny's Avatar
Shore pwr goes thru the converter and powers all 12v appliances even with the disconnect in the off position. When you unplug the shore line then the battery cut off will prevent parasitic drains on the battery.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 07-17-2017, 06:11 AM   #3
wmtire's Avatar
These threads may help you better understand your RV's electrical systems. Mark Polk explains what is powered by what source of power, as well as the battery disconnects purpose and the converters function, as SilhouettePenny stated.
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
Hope this helps
2011 Flagstaff 831 RLBSS
Did you know that thousands of scientists from around the world are looking for a cure for my narcissism?
Old 07-24-2017, 04:42 PM   #4
rracer5's Avatar
I would think that every manufacturer "wires" their units differently (why wouldn't they, remember, they don't and can't supply wiring schematics because each unit is wired by hand). But, in my case, when NOT connected to shore power, the disconnect kills everything except the hydraulic pump which runs the landing gear & slides (which are hydraulic).
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-24-2017, 04:57 PM   #5
bikendan's Avatar
THIS!
Battery disconnect switch is only for when there's no shore power.
Equalizer WDH
Old 08-01-2017, 03:54 PM   #6
King of the Road
On my 27rk Crusader Lite, the landing gear and slide out are the only things that work with the battery disconnect engaged.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 08-01-2017, 04:14 PM   #7
As others have said, it is a battery disconnect, not a 12 volt on/off switch. If there is shore power, the converter will continue to supply 12 volts to the coach, regardless of disconnect switch position.
2015 335DS
ScottBrownstein is offline   Reply With Quote
battery, battery disconnect
