Old 08-28-2014, 04:13 PM   #1
Happy Camper
W3NS's Avatar
Battery Disconnect
I have a Battery Disconnect in my new Lacrosse TT. How does it work? What does pushed in mean and what does push out mean. This is the first time I have had one.
Thanks in advance,
Bill
2015 Prime Time, Lacrosse 324RST Touring Edition, Travel Trailer
2012 Dodge Ram 2500, Big Horn Laramie, 6.7 Cummins Turbo Diesel
W3NS is offline   Reply With Quote
Old 08-28-2014, 04:17 PM   #2
fonzie's Avatar
push in means "disconnected" and pull out means "connected"
Also if you do a search above you will get more threads with info:
https://www.google.com/search?q=batt...com&gws_rd=ssl
Name:	push-pull battery disconnect.jpg
Fonzie
Old 08-28-2014, 04:20 PM   #3
Happy Camper
W3NS's Avatar
Thanks Fonzi. When in the disconnected position, what gets power from the battery?
Old 08-28-2014, 04:24 PM   #4
fonzie's Avatar
I can not say what's gets power from battery when disconnected as it seems every model is different. Look at link above for more info.
Fonzie
Old 08-28-2014, 04:44 PM   #5
Happy Camper
W3NS's Avatar
Thanks Fonzie. I appreciate your help/info very much.
Old 08-31-2014, 10:01 AM   #6
On my Crusader, I have a light just above the disconnect switch. I can never remember if in or out is on or off. So, I just turn the light on so I know when it is off.
When in the off position, I know my auto-leveling system still runs on the battery.
2014 Crusader 296BHS
2015 GMC 2500HD Denali
kohai is offline   Reply With Quote
Old 08-31-2014, 03:18 PM   #7
camaraderie's Avatar
Very often propane & CO detectors are hard wired to the battery and not disconnected.
The only sure way to kill everything for storage is to put a disconnect on the negative terminal on the battery OR simply remove the anything attached to the negative terminal and tape off to avoid shorts.
Here's a switch demo:
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 08-31-2014, 06:07 PM   #8
Happy Camper
W3NS's Avatar
Thanks for all the info! It has been very informative and I appreciate it greatly.
battery, battery disconnect
