Old 02-01-2016, 11:57 AM   #1
Brad Sr
Bradsr51's Avatar
Battery Disconnect Switch on Sanibel
We have a 2015 Sanibel model 3551. What is the proper position for the battery disconnect pull switch to be in when hooked up to park power? There is no marking in the control panel where the switch is located as to on or off positions.
Bradsr51 is offline   Reply With Quote
Old 02-01-2016, 12:09 PM   #2
fonzie's Avatar
Push in to disconnect/pull out to connect......should be pulled out when on shore power
Name:	push-pull battery disconnect.jpg
Fonzie
Old 02-10-2016, 08:32 PM   #3
So what does it disconnect? I do not see anything change.
mlineman55 is offline   Reply With Quote
Old 02-11-2016, 06:30 AM   #4
Fred H.'s Avatar
Look at the tv/radio area. In my unit the radio will not operate if the disconnect switch is turned off. Also the 12 volt lights won't work.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 02-11-2016, 05:34 PM   #5
rracer5's Avatar
In mine, the Lippert hydraulic system (levelers & slides) will still work but, all other 12v systems are shut off.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
battery, battery disconnect, sanibel
