Try charging your battery fully,either with a battery charger or by plugging in to shore power. Your converter should charge the battery. After charging,disconnect your battery from the trailer. If you have a volt meter, you can check battery voltage. 12.6 or so is where a good battery should be after charging and not connected to anything for several hours. Assuming it's good,I would just disconnect battery when you're not going to use it.
1999 Silverado with tow package
2006 Roo 23B hybrid
2006 Roo 23B hybrid
2006 Ford F150 4.6L
