Old 07-25-2011, 09:26 AM   #1
sfrye5853's Avatar
Bed Broke
On the last day of our very first camp out and the jackknife sofa in the bunkhouse got broke. It was layed out in the bed position and the kids were sitting on the edge of it. All the screws holding the frame on the wood deck pulled out. Any suggestions on how to redo this? I can add thicker screws, but didn't know how well that would hold.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 07-25-2011, 09:57 AM   #2
Triguy's Avatar
That's too bad. Can't help with the question about the screws but I would just take it into the dealer as a warranty item.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-25-2011, 11:20 AM   #3
If I was you, I'd attempt to fix it myself, with bigger/longer screws, or add some new wood, whatever is reqiired to fix it. The dealer won't fix it as well as you can do it yourself, from what I have seen. Randy
Old 07-25-2011, 11:56 AM   #4
BigDTx's Avatar
warrenty issue? since this was your first trip, is the TT new and under warrenty?
BigDTx is offline   Reply With Quote
Old 07-25-2011, 12:03 PM   #5
sfrye5853's Avatar
Yes, brand new... first trip out.
2012 Tracer 3150BHD
Old 07-25-2011, 12:05 PM   #6
BigDTx's Avatar
that suxs, atleast it is covered. but still a pain to deal with.
Old 07-25-2011, 03:26 PM   #7
grhodes50's Avatar
An old trick my Dad taught me years ago is, fill the holes with caulk, then stuff with toothpicks breaking them off flush, then reattach with original screws.
I've used this fix a lot of times over the years and it hasn't failed me yet.
Hope this helps.
Gary & Trish
2018 Nights Camped - 5
Old 07-25-2011, 03:52 PM   #8
sfrye5853's Avatar
Hope this helps.
My dad showed me the same trick but used wood glue instead of caulk. Was thinking about that as a possible fix... thanks!
2012 Tracer 3150BHD
Old 07-25-2011, 03:53 PM   #9
sfrye5853's Avatar
Only problem is the deal is an hour away... that means about a half tank of gas and a Saturday shot... I'm thinking a DIY is in my future.
2012 Tracer 3150BHD
Old 07-25-2011, 05:03 PM   #10
grhodes50's Avatar
We always used the caulk because it held well and was easy to remove the screws if need be.
I never tried the wood glue. I don't see how it would be any different. Either way should work.
Let us know how it turns out.
Gary & Trish
bed
