Old 08-26-2015, 09:38 AM   #1
ksting's Avatar
Bike Rack On Bumper With Double Beams
I realize this has been addressed numerous times. I know, I know, everyone says to not mount a hitch on your rear bumper with a bike rack because a bouncing bike rack can break the welds if it's not reinforced. But my rear bumper on my Avenger has doubled up beams supporting the bumper on each side. A lot of trailers only have single beams supporting the bumper. My bumper seems like it's a lot more beefed up and is already supporting a spare tire. I was thinking of removing the tire and replacing it with the bike rack. I have included a picture here. Thoughts? Sorry the picture uploaded upside down but you get the idea.
2014 PrimeTime Avenger 26BH Touring Edition
2005 Chevy Silverado 1500 Z71
ksting is offline   Reply With Quote
Old 08-26-2015, 09:40 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Be a ware you will void your warranty by mounting a bike rack to your tt if your warranty has not expired. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 08-26-2015, 09:41 AM   #3
ksting's Avatar
Manufacturer told me that the warranty is already expired as its only for one year. I purchased this 2014 trailer used.
Old 08-26-2015, 10:00 AM   #4
How thick is the metal the bumper is made of? How far does the double beam extend under the trailer?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 08-26-2015, 10:36 AM   #5
rsdata's Avatar
I am a proponent of adding bumper hitches to TT responsibly. Please take into account the load you are putting on the bumper, any additional load-bearing brackets that you may add, and watch carefully for problems anytime you tow. I took off the factory mounted spare tire and bracket. I also have this mounted close to the right side closer to the bumper support.
I added to my Shamrock 183 brackets to help support the bumper (and help compensate for rotational torque from the bike carrier) from
Mount-n-Lockā„¢ Camper & RV Bumpers, Cargo Carrier Trays and Accessories
to give me a little more strength. I added the Swagman hitch from etrailer.com which features a bolt on the side to help control bounce of the inserted hitch.
I then designed and with the help of a friend that could weld aluminum, built a custom bike rack out of aluminum and stainless. It weighs less then 20#. The stainless tube is inserted into the hitch. The tube is bolted to an aluminum rack that supports the wheels of my bike. It is very stable riding down the road and does not bounce by itself, unless the whole rear of the trailer bounces. My bike and carrier weighs about 45# total.
The attached pictures I just took... the uneven black paint near the welds is the result of spray painting black-rubberized paint in those areas to keep ahead of rust, although in one shot it looks like the weld is cracking... it is NOT...
This was my way of dealing with adding a bike rack to my HTT, and I hope it gives you an idea of what might work for you.
ID:	86963   Click image for larger version
ID:	86964   Click image for larger version
ID:	86965   Click image for larger version
ID:	86966   Click image for larger version
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-26-2015, 10:57 AM   #6
ksting's Avatar
One beam is cut short and bolted to the side of the frame. The other beam extends underneath. The bumper is a standard 4" square.
Old 08-26-2015, 11:05 AM   #7
ksting's Avatar
I have a bolt on curt hitch I already purchased and a bike rack that holds four bikes. I would only use it for two though.
Old 08-26-2015, 12:06 PM   #8
Telstar's Avatar
Be advised that most bike racks warn that they are not designed for use behind a trailer. This is because of the bouncing, the welds on the rack may break. There are a few racks designed to withstand the stress, I find they all cost over $150.00.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 08-26-2015, 12:55 PM   #9
ksting's Avatar
I have a Yakima bike rack. It's at least 9 years old. It won't break. The trailer bumper is more of a concern.
Old 08-26-2015, 01:06 PM   #10
mudman2's Avatar
Do yourself a favor. Get a front hitch. I did. Not only does it bring the bikes along it helps me tremendously to reposition the trailer in my side yard location.
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
bike, bike rack
