Old 08-27-2018, 01:42 PM   #1
Black tank drip
I noticed when I was cleaning the black tank out on my 2014 Forest River Crusader 360BHS it has a steady drip coming from what appears to be around the bottom of the tank. It drips down onto the plastic cover on the bottom of the camper and runs to the drain area where the spray insulation is around the pipe. Any thoughts? Itís not pouring out but definitely a steady drip when liquid is in tank.
2014 Crusader BHS360
14Crusader is offline   Reply With Quote
Old 08-28-2018, 12:01 PM   #2
rracer5's Avatar
That will require lowering the underbelly and looking to see if the dump connection/valve is leaking. If not, hopefully the tank doesn't have a small crack in it.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-28-2018, 12:38 PM   #3
If the tank does have a small crack in it what is a round about cost to replace?
Old 08-28-2018, 02:42 PM   #4
heavynlori's Avatar
We replaced one on our old camper - tank was $150 from a dealer
We did our own install on seasonal site - took me and DH all of a whole day - that camper was NOT an enclosed underbelly
We did have to pull toilet and used Fernco fittings as well
heavynlori is offline   Reply With Quote
Old 08-28-2018, 05:39 PM   #5
Ok thanks for the response. I have a very limited amount of knowledge on what I would be doing so Iím probably going to take it to a local dealer with a good service department.
Old 08-29-2018, 10:40 AM   #6
rracer5's Avatar
Those tanks are pretty durable. I'd bet on a loose clamp where the outlet tube enters the tank. If that's where the leak is you can also loosen the clamp, pull the tube off, clean the flange & tube real good and apply some plumbing sealant & slip it all back together and tighten the clamp.
2014 Sanibel 3250
Old 09-04-2018, 04:58 PM   #7
Witch Doctor's Avatar
I would drop the belly first and have a look. If you developed a crack in either the tank or drain pipe, or where it connects to the tank, go buy some 3M 5200 it's in a tube, you can seal through hall fittings on a boat below the water line, that will seal it for good. They make a quick cure or a 24 hr cure, either will serve your purpose.
Coachmen M/H
Concord
2018 / 300 DSC
black, black tank, tank
