Old 11-25-2011, 07:11 PM   #1
Black water flush
How do i flush my Black water tank? 2012 Crusader ,I connected the blue hose to the quick connect and the other end to the hose connector and then water leaked over on the far side of the basement.(under shower)My book doesn,t say any thing about flushing from the outside.
charliebob is offline   Reply With Quote
Old 11-25-2011, 08:59 PM   #2
M109Rrider's Avatar
With the tank dump open that's all there is to it. I usually hook straight up to the campground spigot with a separate hose (not my pot. water hose) for more pressure . Sounds like you have a leak. Can you see where it's coming from?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 11-26-2011, 10:11 AM   #3
Commercial Member
Blue hose to the quick connect? It sounds like you are trying to use the outside shower hook-up? Not exactly sure what that result would be but neither of those items have anything to do with the Black Tank Flush.
M109 has it right - just connect an incoming water hose direct to the threaded Black Tank connection.
Contact our Customer Service for more detailed assistance:
primetimerv.com
PTM
RV Guy is offline   Reply With Quote
Old 11-26-2011, 10:42 AM   #4
Thanks ,it looks like i was doing it wrong,ill do the seperate hose hookup the next time i dump.A guy here in the park rigged two vavles off the main water ,closes one and opens the other.Thanks again.
Old 11-26-2011, 09:20 PM   #5
Dave_Monica's Avatar
I connect the outside shower to the blackflush connection to flush the the black tank when there's no water connecion at the dump station. You only have the water pump pressure, but it's better than not flushing at all. All you need is a brass adapter...1/2" npt to 3/4" hose.
Dave
Old 12-13-2011, 08:15 PM   #6
yes i was connected to the outside shower , i don,t have any leaks on the city water .so that tells me i have a leak on the pump system. the water came from under the inside shower.i did end up flushing with a separate hose.it worked,,I'm going to use the pink stuff this week to check and see if the leak is in the pump system.if it is that means the shower has to come out to fix it.we are going south in two weeks so it may get fixed next spring.i will call pt tomorrow.thanks.
Old 12-13-2011, 09:43 PM   #7
Lottery Non-Winner
Ovair's Avatar
When you say blue hose, do you mean this?
Or do you mean this?
It makes a major difference. The second blue hose has nothing to do with the black tank.
I'm not sure how your rig is set up, but many have a black water rinse that is labeled. Just hook up a regular hose to it (but preferably not your drinking hose).
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 12-14-2011, 06:06 PM   #8
yes the small blue hose,i found out thats a no-no.i believe i found where the leak is, there is a pipe chase along the wall in our bedroom,i bet i find a tee behind that pannel.Ill post tomorrow.thanks.
Old 12-16-2011, 08:45 AM   #9
just water lines,no tees.
Old 12-16-2011, 12:42 PM   #10
Up-date, I called PT and got Roger on the phone,He made a trip over to the factory to see how the lines were runing in the basement.He told me to look behind the shower faucet,BINGO,,,there is a vent of somekind that was loose.It took about 15 min, to fix.Thanks Roger.
black water
