Old 06-19-2014, 05:33 PM   #1
Blowing Fuse on Tow Vehicle
I have a 2013 Ram 3500. In the last two days, seems when I hook up the 5th (325res) I blow the fuse on the truck that controls the lights on top of the cab and on the fenders. Any suggestions, it is a 15amp.. All the lights on the trailer work fine. Thanks in advance.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 06-19-2014, 06:00 PM   #2
If the fuse blows, how do you know the lights all work fine? Sounds like you have a short somewhere. It could be some place where the wires are being pinched (you'll have to trace all the wires, a potential PITA). Or it could be one of the lights has blown and shorted itself out in the process. Doesn't happen very often, but it does happen.
2011 Traverse LT, 3.6L, FWD
Old 06-19-2014, 06:03 PM   #3
markb5900's Avatar
You have a dead short somewhere.
Start at the 5th wheel plug and work back till you find the wire that is bare and shorting to the ground on the truck.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 06-23-2014, 09:21 AM   #4
rracer5's Avatar
Are you saying that even after the fuse blows, ALL the clearance lights, side marker and tail lights on the trailer stay lit?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-23-2014, 09:55 AM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
How old is your 5r? The 5r cable (not connector) could be faulting.
donanddona is offline   Reply With Quote
Old 06-23-2014, 10:11 AM   #6
TURBS's Avatar
Camper fuses are separate from truck fuses.
Old 06-23-2014, 10:13 AM   #7
TURBS's Avatar
Almost all newer trucks us separate fuses for a towable.
That way if your camper has a short your truck stays lit.
Or visa versa
This goes for turn tail and stop.
Sooooo it's most likely in the truck wiring.
fuse, tow vehicle
