Old 04-13-2014, 02:16 PM   #21
dmf564's Avatar
And if the fuse isn't blown....
Sent from my DROID BIONIC using Forest River Forums mobile app
[SIGPIC]TV-2012 Ford F250 XLT Supercrew 4X4
TT- 2010 Jayco Jay Flight 17Z (traded)
TT- 2012 Coachman Catalina 30BHS (current)
Me and my wife with 3 kids love camping!!
dmf564 is offline   Reply With Quote
Old 04-13-2014, 02:35 PM   #22
Tie a 15 amp fuse to it and touch the fuse to the pos side of the battery. If it doesn't blow, try to operated one slide.
Old 04-13-2014, 07:19 PM   #23
dmf564's Avatar
I've you figured it out yet?
Old 04-13-2014, 07:22 PM   #24
sfrye5853's Avatar
No... can't get to the motors to test wires with the slides in. I'm hoping forest river can tell me where it goes. I plan to call them Monday.
Sent from my DROID RAZR HD using Forest River Forums mobile app
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 04-13-2014, 07:25 PM   #25
Try the fuse idea, worse thing that can happen is blowing the fuse.
Old 04-13-2014, 07:51 PM   #26
VinceU's Avatar
dmf564 you might be on to something. I went out to look at the battery and saw this cable. Now I have no idea where it goes... any help with this?
If OC's idea with the fuse doesn't work, remove and clean all battery connections to bright metal and seal with elec grease or terminal paint. The two pos leads look to me like the DC bus feeder and the slide feeder. Need to locate the length of both just beyond the battery and look for inline fuses. Usually they can be reset with a button. Finally, locate the slide negative connections to the frame, the motor must have pos and neg. to work. That extra "cable" you found doesn't look big enough for two slide motors and does not look like factory supplied wiring.
Old 04-14-2014, 10:45 AM   #27
sfrye5853's Avatar
Prime Time called me and told me that wire is the ground for the slide out motors. I am supposed to connect it to the negative battery terminal. It will be a few weeks before I get back to it but I will update the post after I get it connected.
Thanks for all the feedback and help.:thumbup:
2012 Tracer 3150BHD
Old 04-14-2014, 10:51 AM   #28
dmf564's Avatar
Glad to hear you got a quick response out of them.
Old 04-14-2014, 10:54 AM   #29
Brother Les's Avatar
They told you that the Red wire is the ground wire?
Brother Les
Old 04-14-2014, 10:56 AM   #30
sfrye5853's Avatar
Yep... its red and black, but yes they did.
2012 Tracer 3150BHD
slide, slide out
