Old 08-28-2016, 10:35 AM   #1
Brake hub problem- FYI
We are planning a trip to the Oregon Coast in September. In preparation for that trip I decided to lube the axle bearings on our 2015, 294RLT. All went well until the rear axel on the driver side. As I spun the wheel while adding grease I heard a clicking sound on each rotation. I removed the wheel and hub and discovered a real mess. It appears one of the five nuts that hold the brake housing onto the axle came off at some point in time. This seems to have caused the magnet to wear down to the copper coils, scarred the drum, and wore the brake shoes down to bare metal. The nut was still inside the the area, captured between the drum and brake housing. It was worn as if being on a grinder, the star washer is not to be found. I will submit pictures for a claim but must get this repaired locally as time is a factor. This could have ended in a real problem, but fortunately it was discovered in my driveway and not on the road. I will pull all the other hubs for inspection prior to any travel. This appears to be one time my "over-doing" it paid off.
xcopper is offline   Reply With Quote
Old 08-28-2016, 11:00 AM   #2
Iwannacamp's Avatar
IMO if you can do what you are doing you can fix it. Just buy a backing assembly and drum if needed. $100 should be close. Install. Adjust brakes. Back in action
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Old 08-28-2016, 11:07 AM   #3
toslow's Avatar
X2 would be the lest painful
haven a blast
toslow is offline   Reply With Quote
Old 08-28-2016, 05:57 PM   #4
M109Rrider's Avatar
I just replaceed a backing plate on my 320rlt. 12x2 complete backing plate with shoes and magnet was $54 at a local trailer supply place. I couldn't replace the magnet and shoes separately for that price.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 08-28-2016, 11:18 PM   #5
Thanks for the suggestion of replacing entire brake assembly. I will contact local suppliers in AM to find the assembly, then install. Still plan to check other 3, for peace of mind if nothing else. May be a little more labor, but better at home than on some highway gravel shoulder.
Old 08-29-2016, 02:28 PM   #6
Update
Located Dexter parts locally. Replacing entire brake assembly, drum, bearings and seal for cost of $135. Add wheel bearing grease and blue locktite for another $12. Called Dexter and it appears likely they will reimburse for brake and hub. Very cooperative person at Dexter. I think this is not an unknown situation.
Old 08-29-2016, 04:59 PM   #7
Check all the bolts for lock washers. Mine had none. Check other wheels too.
Harkerr is offline   Reply With Quote
Old 08-30-2016, 10:32 AM   #8
Example of what one little nut can do
As pictures show it would only been a matter of time before a roadside breakdown occurred. All replaced and good to go. Sent pics to Dexter, waiting for reply.
ID:	118827   Click image for larger version
ID:	118828   Click image for larger version
ID:	118829   Click image for larger version
Name:	Brake Shoes.jpg
ID:	118830   Click image for larger version
Old 02-13-2017, 11:31 AM   #9
It has been quite a long time since I first posted the problem with my hub and brakes. I have been slow to update and for that I apologize. Dexter has reimbursed me for the costs incurred to make the needed repairs. People at Dexter seem quite helpful and willing to assist. In the future, even though I have the ez lube hubs, I will remove the hubs yearly for inspection and bearing pack. Another over-do, I am sure.
Old 02-13-2017, 11:49 AM   #10
On our complete New axles we had the Socket Head Bolt fall to the Inside where your Nut was doing its Deed! You should see what kind of Damage that did! I got to repair that in Durango,CO.! Same parts required as yours! Youroo!!
