Old 08-23-2017, 07:36 AM   #1
071567's Avatar
Break away cable
On my break away cable for my breaks where is the best place to attach it to. I've been placing it over the handle that releases the king pin,and it keeps coming off when traveling. I was wondering if any of y'all had this problem,and if so how did y'all fix it.
071567 is offline   Reply With Quote
Old 08-23-2017, 08:00 AM   #2
I switched to this
https://www.amazon.com/Fastway-80-01...reakaway+cable
and attach it where the safety chains go.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 08-23-2017, 08:48 AM   #3
071567's Avatar
Can't you just put a clip on the end of the cable and still hook it to where the safety chains go.
Does 5th wheels have safety chains because mine dont
Old 08-23-2017, 08:53 AM   #4
Sorry I didn't notice that you had a fifth wheel.
Les & Heidi Kramer
Cleveland, OH
Old 08-23-2017, 09:04 AM   #5
saus's Avatar
After I close the jaws I take the safety lock pin that holds the jaws closed, put the pin through the loop of the cable and put the pin in to lock the jaws closed. The cable remains attached by the pin and because it is a safety lock pin, it is closed and can not come loose.
2016 Forest River Wildcat 314BHX
2018 Ford F-350 DRW 6.7 Diesel
saus is offline   Reply With Quote
Old 08-23-2017, 09:10 AM   #6
DaveSchwartz's Avatar
My breakaway cable has a carabiner on the end (I think that was factory) and I hook it through an unused slot in the hitch rail.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 08-23-2017, 10:07 AM   #7
Head Rambler
I use a carabiner as well. Hooking it to the bed rails is a good idea.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-23-2017, 10:25 AM   #8
Iwannacamp's Avatar
I would like a better than the handle connector as well. I have thought about welding/mounting something somewhere....
To the OP. I have read about the angle of mount on the break-away switch...if it's at an odd angle it can break instead of release...just something else to look at. Mine looks like it points down about 45 deg. this prolly means at the point of requirement...it would break.
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 08-28-2017, 07:44 PM   #9
GeoArm's Avatar
I loop it around the handle then hook it in the pin to lock the handle in the closed position of the 5 th wheel. Never had it come off
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 08-28-2017, 07:49 PM   #10
071567's Avatar
When you turn does the cable get tight or pull it out
Old 09-02-2017, 10:35 AM   #11
M109Rrider's Avatar
Caribiner to the hitch rail works great for me.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 09-02-2017, 10:59 PM   #12
071567's Avatar
Only thing is I don't have a hitch rail. I have a B&W hitch that sits where the goose neck ball sits at
cable
