Old 11-14-2015, 10:49 AM   #21
Platokidd's Avatar
Exclamation try this....
try expanding the manage attachment box to see the upload button?
For me its hidden, I have to expand the box or I cant see the upload button.
Gosh, now I really like to see some pics of this bubbling !!
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 11-14-2015, 11:40 AM   #22
Campground host Mo. State
Photogirl's Avatar
Caller Prime time talked to cust.service, he thinks the electric box behind the microwave may have too long screws or it is putting pressure on the wall.yesterday i pulled the micro. and fastened the box with shorter screws so far the bubble is still there.
Photogirl is offline   Reply With Quote
Old 11-14-2015, 11:44 AM   #23
Photogirl's Avatar
will try expanding.
Old 11-14-2015, 11:46 AM   #24
Photogirl's Avatar
The bubble is about 10 inches above the vent. will try to get a better pic ,thanks for the upload help expanding was the trouble.
Old 11-14-2015, 03:43 PM   #25
That is a bonded wall not loose hung or "floating as that guy said", that bubble is a problem that you need to get repaired! If you push on it does it feel like the fiberglass has a hard backing(still attached to the Luan) or just a thin sheet without a backing?
2014 Crusader 335BHS-TE
2017 F-350 6.7L CC flat bed
Nights Camped in this unit.
2017 3 so far
2015 57/2016 52
2014 40/2013 38
keepaeyeonit is offline   Reply With Quote
Old 11-14-2015, 09:09 PM   #26
Photogirl's Avatar
Bubble
Will have to bring a ladder to our storage lot to be able to reach it.
Old 11-15-2015, 06:40 PM   #27
Steveinthehills's Avatar
Your dealer is giving you a run around....."Floating Wall" I don't think so. It's a fiberglass issue. The factory replaced my entire wall.
Steveinthehills is offline   Reply With Quote
Old 11-16-2015, 08:13 AM   #28
Originally Posted by GSlone View Post
I have a toyhauler 28WP and the slideout has what looks to me like a bubble but I took it back to the dealer (had it almost a year and a half) but they said it was a "floating wall" and normal.
Isn't a Cherokee Wolfpack 28WP a stick and tin trailer?
That very well could of been the case but removing the screw after the fact most likely won't fix it. If it was a screw it pushed the fiberglass away from the luan or the luan away from the foam, breaking the glue bond. Since it does not appear to go all the way to the top of the slide it doesnt look like its due to water intrusion but you never know. I agree with others, that's a factory repair.
Mr Havercamp is offline   Reply With Quote
Old 11-16-2015, 08:10 PM   #29
VinceU's Avatar
The wall is a sandwich glued with pressure and heat. The process does can fail from time to time, glue control, heat control etc. Any failure necessitates a change of the entire panel. Not the same as boat, no thin laminates glued together. No bubbling is acceptable, it will only spread with moisture. Rot and bugs follow inside follow.
Old 11-17-2015, 08:37 PM   #30
Photogirl's Avatar
Bubble
Went to our storage lot today it was raining pretty hard and the side wall was wet and cold but the bubble seems to have went down we could not see it . Keeping fingers crossed.
slide, slide out
