Old 06-30-2012, 11:16 PM   #1
JoeyO's Avatar
Send a message via Yahoo to JoeyO
Bug light above door burnt out - Tracer 3150
How do you change out the bulb that is over the outside door? It's sealed with caulk all the way around.
Do I need to cut out all the caulk to get to the screws? Please let me know.
Thanks! Joe
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 07-01-2012, 05:55 AM   #2
Nope, just pop off the colored cover...The look at it closely, it was pretty easy to remove.....bought the bulb at the campstore at Frontiertown when mine burned out....... Pretty standard bulb. I forget the number.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 07-01-2012, 09:00 AM   #3
weiman1983's Avatar
Send a message via Skype™ to weiman1983
I agree with padave65. You only have to take off the colored lense. It's actually quite easy and should only take you a few minutes. Sqeeze the top part of the lense and slide it down. I forget the part number on the bulb, but you can get it at any hardware/rv store.
weiman1983 is offline   Reply With Quote
Old 07-01-2012, 02:23 PM   #4
JoeyO's Avatar
thanks a bunch! I wasn't about to go squeezing lenses just yet! Were camping next weekend in IN for five days so I will tackle it then!
Cheers! Joe
OTeam
2018 Genesis G80
Semper Fi
Old 07-02-2012, 12:28 AM   #5
Chuckinca's Avatar
My unit has a clear lens light on the nose and I switched bulbs to the bug light until I could buy one at Wally World.
I put a small flat blade screw driver in at the indentation on the bottom center of the lens, turned it and the lens popped out.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 09-02-2012, 03:54 PM   #6
bug light
I had the same problem with my new Crusader 325res. Replaced the bulb and blew it out the next night. The 1003 has 11 candle power, to hot to be contained under the lens. Talked to friend who manages Napa Auto Parts store and he suggested the 89 bulb at six candle power. Not quite as bright, but still produces plenty of light. It also burns much cooler. I tried it and it solved the problem. Bodymaker
bodymaker is offline   Reply With Quote
Old 09-02-2012, 06:27 PM   #7
We had problems with ours burning out. At best they lasted 3 days. We replaced it with an LED bulb, and not problems since.
Laura is offline   Reply With Quote
