Old 11-14-2012, 12:29 PM   #11
Originally Posted by phrogdriver93 View Post
I bought the largest size last year for our 318BHS. It's worked great, but did rip a bit around the lower corners and lower fol out stairs. I tried both the tennis balls and the swim noodles to cover the sharp points, but couldn't get them to stay on very well. Still a great investment IMHO, as I can live with a few minor tips on the lowest (insignificant) portion of our TT.
I got a little tear at the corner of the steps too. I used the patch material to repair the tear. I ended up using cardboard and duct tape to cover the corners on the steps.
Len & Cheri is offline   Reply With Quote
Old 11-23-2012, 05:06 PM   #12
The 318 Touring Edition measures 31'-11" from the rounded nose to the back. I measured ours last week.
2012 Lacrosse 318BHS
2010 F-150 Max Tow
21C1 is offline   Reply With Quote
Old 12-10-2012, 07:30 AM   #13
Cover Update
Just an update on my purchase.
I purchased the 31'-7" to 34' version of the Designer Series
It fit perfect with room to cover the spare tire at the back.
I am glad I didn't get the longer one.
Dandy is offline   Reply With Quote
Old 12-10-2012, 08:35 AM   #14
rattleNsmoke's Avatar
Glad you got one. It seems either peeps love or hate covers. We have one on "The Beast" and thank God we do! During storm Sandy, a huge oak tree toppled into another tree which toppled into a third which came down and it's branches just grazed the trailer. Without that cover, we would have had severe scatches down the side. The cover was torn in several spots, but it did more than I could ever ask. No visible damage! I'm a believer.
rattleNsmoke is offline   Reply With Quote
Old 12-10-2012, 09:01 AM   #15
I removed my cover yesterday to start getting the TT ready for our end of month trip. The wifey would feed the cover into a large trash barrel as I removed it from the top of the TT. It went very smooth.
The cover did it's job too. The TT is spotless and I won't have to wash it before going camping.
Old 12-10-2012, 09:42 AM   #16
BigTJohn's Avatar
Covers are great! But I covered the spare on our last TT and had massive mold growth on the tire cover, inside n out. Then I read the install instructions - do not cover the spare. Then I ask myself, why did you (ADCO) ask me to measure the tongue to rear bumper, including spare, when you tell me in the insall inst. not to cover the spare OR the front of the tongue?? After sterilizing the spare cover, we only covered the the "box" and it worked out well, with tennis ball protectors on the gutters and swim noodles, slit lengthwise to cover any sharp areas at the bottom. No problems. Too much slack will allow the cover to move around and wear through at corners, etc. The plastic trash can works very well for storage and transporting like Len & Cheri mentioned.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 12-25-2012, 09:08 PM   #17
Dosent the cover trap moister inside ? I have heard good and bad things about them, I have never used one. But it would be nice to wax in the fall, cover, and be ready to go in the spring
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 12-26-2012, 04:06 PM   #18
BigTJohn's Avatar
No moisture is trapped, some may be passed but it evaporates quickly. The Tyvek top portion is quite waterproof.
Brenda and John
Old 12-26-2012, 06:36 PM   #19
I have the Tyvek Designer cover and have used it for almost 4 years. Really glad I purchased it, but had little tears on it until I learned where the wind can wear holes. As mentioned, where the stairs fold in have sharp corners, plus gutter extensions, and the Wingman has sharp edges. I have the Cyclone vents which I cover with small plastic trash cans. I also use tennis balls with the X-cut, at the step bracket corners and gutter extensions. I hold those on with metal tape available at Lowes. Very important to have the strong tape because you will check on your cover and those tennis balls will fall off. Duct tape might fall off with cold/heat temps. I use a carpet remnant(3'x3') and lay it on my TV antenna. To repair any holes in the cover, I use my left over EternaBond. Works great and has not fell off anywhere I had trouble. My left over or extra material on the cover I pull over the tanks, electric jack, and tongue. I went to Harbor Freight and purchased the plastic tarp clamps, along with 1/4" rope from Walmart and secure the excess. Works great and hope this helps.
2006 Rockwood 8272S
2005 Chevrolet Silverado
John & Pandra
Battlefield, Missouri
F.R.O.G. Member
1st International F.R.O.G. Rally Branson Missouri
JohnandPandra is offline   Reply With Quote
318bhs
