Old 07-06-2012, 07:38 PM   #1
Camp Chef grill
After some research I decided on the CampChef MVP sport grill. Haven't tried it yet but thought i would tell you about my mod. I ordered several model 250 propane quick connects that fit my Crusader, had the local propane place make me a 20ft hose with the quick connects on it. I then went to the hardware store and bought a 3/8 female flare to 3/8 female pipe thread adapter. this adapter threaded right onto the propane inlet on the grill! Worked great and only cost about $1.50 not including the longer hose, works fine with the short hose, too. The OEM connector had a needle that depressed a recessed Schrader valve on the regulator end allowing propane flow only when fully engaged. the flare adapter threaded right over the needle so no cutting or anything just a wrench and some thread tape.
2004 GMC Sierra 2500
2012 Primetime Crusader 298BHD
sbelliott is offline   Reply With Quote
