Old 05-19-2013, 11:47 AM   #1
capture plate
I know I don't need a slider but before we bought the 325 RES i had a chance to buy a super glide at a really good price. For those of you that have a superglide hitch which capture plate will I need for a Crusader 325RES. thanks ron
rhollar is offline   Reply With Quote
Old 05-19-2013, 04:20 PM   #2
Look on your pinbox and see what model it is. Then go on super glides web page and it will tell you what you need.
southernsky is offline   Reply With Quote
Old 05-19-2013, 04:33 PM   #3
jevanb's Avatar
get the capture plate for your pin box not the universal plate
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-19-2013, 05:37 PM   #4
zs325RES's Avatar
Congrats on your new 325RES!
I've got a Curt manual slider, but don't even need it.
Enjoy!
2013 Crusader 325RES Touring Edition
2018 GMC Sierra Denali HD crew/SB L5P Duramax
zs325RES is offline   Reply With Quote
Old 05-19-2013, 07:45 PM   #5
capture plate
I have not picked up the trailer yet, getting it this Saturday. I have two plates from the guy I bought it from one is for Dexter, Fabex, lippert and Leland pin boxes. Liberty is going to have a plate if my isn't the right one. hope mine is good, don't want to spend any more money, but i will to be safe. Wasn't planning on getting new camper but wife loves the 325res. Sold my TT in lest than 10 hours on craigslist. Thanks Ron
Old 05-20-2013, 08:44 AM   #6
zs325RES's Avatar
I'm pretty sure the chassis is made by Lippert if that helps. Pin box too probably.
Same thing about my DW. Once she saw the 325RES, she wouldn't talk about anything else.
Sold my 20 year old fold down on Craigs List too.
Old 05-20-2013, 08:50 AM   #7
Herk7769's Avatar
There are several plates for Lippert pin boxes.
Here is the current list.
https://docs.google.com/viewer?url=h..._Fit_Chart.pdf
A phone call should clear it up.
The dealer had the installed pin box information the same day.
HAM CALLSIGN - KC3FFW
Old 05-20-2013, 08:58 AM   #8
jonandjolene's Avatar
Be sure to get the bolt on one instead of the weld on. That way if you have problems, you can pull it off and anyone can pull the trailer. I have a Pull-Rite slider hitch and use a Lippert Capture Plate.
JonandJolene
2013 Blue Ridge 3125RT
w/ TrailAir suspension
2015 Ford F250 4X4, 6.7 PSD
Pullrite Slider Hitch
jonandjolene is offline   Reply With Quote
Old 05-20-2013, 09:24 AM   #9
Herk7769's Avatar
I agree, the custom one is the only way to go.
Mine just pops off with an allen wrench if I need to get the camper towed to a campground.
If you have the universal bolted or welded onto the pin box, Superglide makes an conversion adapter for the tow guys (that most do not carry). If I had one of these I think it would be a worthwhile investment.
It uses the adapter and your hitch head to allow any hitch to pull your camper.
https://docs.google.com/viewer?url=h...dfs%2F3336.pdf
Old 05-20-2013, 09:30 AM   #10
BombDoc's Avatar
Herk,
I suspect I have the same capture plate as you do, or one very similar. Do you notice any movement of the plate? Mine also pops off with the removal of allen screws. I have noticed when I take off from a dead stop, or almost come to a complete stop, a clicking sound. Over this weekend, while disconnected from the trailer, I was able to use my hand and push on the capture plate. There is movement and I suspect it is what makes the noise when starting and stopping. It doesn't appear that any adjustments can be made as the set screws are fully seated. Just wondering if this minimal movement is normal.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 05-20-2013, 12:52 PM   #11
Herk7769's Avatar
Does your capture plate still have the nylon block?
Mine is cracked and I was going to email Pullrite to have them send me a new one. I think if that block breaks that there would be quite a bit of play in the plate.
HOWEVER, The plate should not move when stopping or starting!
It is there to marry the hitch head to the pinbox ONLY. There should only be force on it when turning (side force). Pin retention is handled completely by the hitch head.
ID:	30938   Click image for larger version
Old 05-20-2013, 01:08 PM   #12
I still have the nylon block intact. As I just traded 5th wheels, I had the dealer put a new plate on. My old plate was a weld on type. Time will tell how long the nylon block lasts.
JonandJolene
Old 05-20-2013, 01:29 PM   #13
apture plate
Just talked to dealer, I need part number 331704, which I think I have . Yea
Old 05-20-2013, 01:36 PM   #14
slide5r4fun's Avatar
Originally Posted by BombDoc View Post
Herk,
I have noticed when I take off from a dead stop, or almost come to a complete stop, a clicking sound...
Hey BombDoc, if the hitch is out of adjustment you will have some play the turntable cam assembly. If so, you will need to adjust the threaded stop assembly. Mine would "clunk" every time I stop/started before I adjusted it. Does your cam assembly move around when your are not towing? If so, that's a good sign you need to adjust it. Takes about 2 minutes.
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 05-20-2013, 01:48 PM   #15
Herk7769's Avatar
Yep. times 2
Old 05-20-2013, 02:12 PM   #16
BombDoc's Avatar
Thanks for that advice. It does move around some when not towing. I will investigate that tonight! Thanks.
2013 Sabre 32RCTS-6
Old 05-20-2013, 02:22 PM   #17
Herk7769's Avatar
here is the adjustment procedure:
Name:	Cam Adjustment.jpg
Old 05-20-2013, 04:53 PM   #18
BombDoc's Avatar
I think after reviewing the literature, my hitch needs some adjusting and that will do the trick! Here is a pic I tried to describe. Four (one on each corner) hex Allen screws hold this plate on. You may be able to see in the pic where the movement back and forth has caused the treads on the Allen screw to dig into the plate. Thanks for all the suggestions!
2013 Sabre 32RCTS-6
Old 05-20-2013, 06:00 PM   #19
jevanb's Avatar
I installed 1/4 inch spacers on my capture plate sides, now it is rock solid and will not rotate a few degrees, also i have the conversion adapter but since my capture plate is held on with a allen screw it is removable in 2 minutes, plus the nylon block that the screw holds on against the pin box I also made mine out of 1/2 aluminun
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
