Old 10-24-2011, 10:50 AM   #1
Cold Bathroom! - Tracer 2670BHS
Went camping this past weekend and the temperatures dropped at night to about 30's. The camper stayed very comfortable but the bathroom was extremely cold! There is one vent under the tub but it seems like very little air comes out and it doesn't get hardly warm at all.
Any ideas?
Dwayne
dapersico is offline   Reply With Quote
Old 10-24-2011, 11:06 AM   #2
sfrye5853's Avatar
I wondered about that. We have the same one vent. Last camping trip we were on the temps got down in the low 50's, but the bathroom was still OK.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 10-24-2011, 11:38 AM   #3
Dave_Monica's Avatar
Dwayne
Plug in an electric heater.
We always use electric heaters as much as the sites' service will allow and only run the furnace if necessary. It's very difficult to balance the temperature throughout the camper using the furnace as the only source.
I'm assuming that you also have the bathroom roof vent open a bit.
Dave
Old 10-24-2011, 12:51 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
Any ideas?
Dwayne
Are you sure it's a heat vent? It should have a flex duct attached to it. If so it may have come apart. I've seen some that were actually used as an access to the trap and leaving it open helped to keep the trap from freezing during cold weather camping.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-24-2011, 01:16 PM   #5
Good point.
Had that in our Rockwood 2605 TT. There was a removable vent cover on the lower wall of the tub enclosure that was access to valves for the low point drains.
Dave
Old 10-24-2011, 09:58 PM   #6
HondoPatrick's Avatar
Daper,
We have the 2670 also and our bathroom is the coldest part of the travel trailer while running the air conditioner or furnace. I do get a pretty good amount of heat coming out of the vent you're referring to while running the furnace, but I leave the ceiling vent cracked at all times. For us, a little colder works as it keeps my lovely wife from falling asleep on the toilet!
HondoPatrick
2012 Ford F250 Lariat FX4
2012 LaCrosse 318BHS w/4 Point Equal-i-zer Hitch
2 Wilderness Systems Kayaks
Nights Spent Camping in 2011 (19), 2012 (16)
http://www.armadillotimes.com
HondoPatrick is offline   Reply With Quote
Old 10-25-2011, 12:04 AM   #7
You might have to leave the bathroom door open at night. We do, to keep our bathroom warm. No heat vents in it at all, and when the door is shut, it stays cold.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 10-27-2011, 12:35 AM   #8
flyrotor's Avatar
Originally Posted by HondoPatrick View Post
Daper,
That's funny, had to look twice to see if I was in the Jokes and Humor section....
flyrotor is offline   Reply With Quote
Old 03-21-2012, 04:01 AM   #9
2012 Tracer 2670
Daper,
I have same model. When furnace is on, cool air blows out from the vent under tub. Anyone know of a fix?
BuffaloOkies is offline   Reply With Quote
Old 03-21-2012, 07:24 AM   #10
cfsoistman's Avatar
I wonder if the flex line that's attached to that outlet is insulated? or the insulation is missing allowing the cold to drop the temperature of the air coming out of the duct? Is the flex duct visible anywhere?
to the Forums. I'm sure someone with the same unit will have a solution for you.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
