Old 08-30-2015, 10:57 PM   #1
cold weather resistance?
So we've had a great summer camping in our new Tracer Air 250. Weather is starting to get colder now, especially in the mountains. I'm camping this coming weekend for 3 nights, and the lows are supposed to be in the high 20s. My trailer has "heated and enclosed underbelly" but not sure how well that will work. I don't have tank heater pads (or if I do, there is no control to turn them on and I don't think the batteries would run them anyway). As far as I know, there is just a heating vent plumbed into the enclosed underbelly that runs when the furnace does.
So my question is, how well does this system work? I'll be primitive camping, so water tank will be full and my generator will run during the day to recharge the batteries from running the heater at night. Am I in any danger of freezing anything or doing damage to the water system? I'll have the thermostat inside the trailer set at 62, just not sure how well the underbelly is insulated or how much that one heat vent does as far as keeping things from freezing......
coolzzy is offline   Reply With Quote
Old 08-30-2015, 11:31 PM   #2
Cypressloser's Avatar
High 20s is just below freezing, I wouldn't worry bec. there is enough residual heat being radiated from the trailer to keep things from freezing and if an exposed line does freeze it will only be for a short time and then thaw in the morning. It is temperatures below 25 for an extended period of time you should be concerned of.
2013 RAM 3500 Dually Longhorn
2014 Trilogy 3650RL, W/D, Onan 5500, 8000# Axles, IS, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-31-2015, 12:04 AM   #3
Just a member
kandl's Avatar
X2 - shouldn't be any issues with the anticipated temps. We've spent many nights just below freezing with nil adverse effects. Even a city water connection under pressure will not normally freeze over night unless the below freezing temps are sustained.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
